![]() Join Date: Mar 2011
Engine Stand Position
My stands look like they will line up in the rear holes .....just checking they came out of a LWB putting same 327 3 speed set up for now in a SWB bell housing sitting fine bolts started thru the crossmember just asking my LWB stands r forward ..?....?
Thanks Jess Posted via Mobile Device
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
Ridin' Dirty
Re: Engine Stand Position
By engine stand, you mean motor mount?
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
Yes the mount that attaches to the frame then the rubber/metal mount that's on the motor attaches to that with one bolt up thru the bottom can't provide pictures right now I am traveling
Ridin' Dirty
Wheelbase will not effect motor mount position if that's what you're asking.
Thanks Mr Pops that was the question ultimately just wondering why my 67 283 the mounts r forward and these look like they will be in the rear wholes.....on the frame
optomistic ah-so
If the shorty is a K-10 (4wd) or if it was big block the trans mounts will be in the rearward position (with a shorter driveshaft for the application) and that will dictate your engine mounts line up with the 4wd (rearmost) holes in the frame.
Some people have taken advantage of this when swapping engines, just to move a small-block back. I've also heard them called "the 6-cylinder position" before, but never looked at one closely, so 6-cylinder trannies may mount in the same rearward hole.
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. ![]() |
