LS Swappers, What did you use, and what did it cost?
Ok, so I have decided the route for my 67 C20, and it's a 6.0L LS swap.
My question for you guys is: What kit or parts did you use, and what did it cost you? I haven't decided which way I want to go, whether it's a full FI/DIS swap, carb and DIS or carb and dizzy setup, (#1 or 2 are most likely), but I want real world, I did this and it is now running perfect numbers. I plan on using a JY engine, which has risks, but is significantly cheaper than any other options. Let me hear it!
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A Last edited by ed2552; 02-06-2012 at 04:27 PM. |
Re: LS Swappers, What did you use, and what did it cost?
![]() Join Date: Jul 2010
Headman headers, holley or trans-adapt plates, and bolt it in. Use the web directions to rework your harness, and have the ECU flashed. Then run it.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
#4 | |
Still Learning
As far as cost, I'm into mine for about $2700 including Engine transmission, exhaust, fuel system electrical, PCM reflash and misc. other expenses. You could probably do it cheaper or spend WAY more. Mine is a 4.8/4L60 bought on Craigslist. You will have a bunch in a 6.0 junkyard or otherwise. I would be happy to help you any way I can if you decide to pull the trigger.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 02-06-2012 at 05:27 PM. |
One thing to watch for if you want to run the front mount dist is that not only do you have to buy a dist you also have to buy a kit that includes the new front cover, new water pump, new harmonic balancer, and pulley kit to clear the new cover that cost around $1500. When I do mine I'm gonna run an intake/carb setup with a msd box to control the coil packs.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
#6 | |
Still Just Havin Some Fun!
![]() Join Date: Jun 2007
a green one with some stuff done to it.... |
Here are a couple of items that made my swap easy.
Motor mount kit from CPP part # CPLS1-K. kit comes with plate and hardware. Headers - I installed Doug Thorley's, they fit like a glove. You can find them for under $500 shipped. ![]() ![]()
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
Just added mine up (5.3L), $2725. That includes headers, full exhuast 4L60E tranny, wiring harness, multiple fittings, fuel tank, sensors.
I did some swapping and selling, so that includes those items too. Such as, I bought the engine with a corvette oil pan, sold that bought a truck pan, sold that got an F-body pan. Did similar things with wiring harnesses too. For me, since my truck didn't come with an engine or tranny, it was pretty much a no brainer. I decent running 350 and TH 350 with headers and exhaust and everything else probably would have run at least $2k |
![]() Join Date: Dec 2007
I'm at about $3800, however, I started with the LQ4 and bored it to a 370, added LS6 heads, cam, etc. Using 4l80e trans. I used ECE's motor mounts and the Thorley headers are simply fantastic. If you go with a custom FI fuel tank, add at least 800 clams to that figure. Plug and play harness? Another 800 bones.
I stayed with factory flashed puter and modified my own harness. I've had the GMPP dizzy setup, but sold it when I mocked it up. Not real appealing to me and seemed like a step in the wrong direction. That's my $.02....... Good luck and keep us posted. |
Great info guys, this is what I need.
I was leaning away from the GMPP dizzy setup, but wasn't sure. But $800 for the DIS versus $1500 for a dizzy? No question, lol. I'll probably run a stock intake and FI setup, as it's a 3/4 ton truck, i'd rather have the torque from the truck intake than the looks from the LS1/6 intake.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
Trkfrk can you point me in the right direction for those dt headers for under 500.00 shipped?
