Old 02-06-2012, 06:20 PM   #1
Andyboy
Andyboy's Avatar
rearend seal leaking
Ok I unbolted the drive line and tried to remove the nut from the rearend, but no luck. I even had the truck on the ground and could not break it loose. The truck would move backwards when I would try and break it free. Is there a trick to remove the nut or did the PO tighten it to much.?
I don't have an E-break also. Thanks
Andyboy is offline   Reply With Quote
