Old 02-06-2012, 06:40 PM   #1
mgkgmc
mgkgmc's Avatar
Painting a GMC grille
I have a 72 Gmc grille that I want to paint the center black again. Any tips of what paint I should use and how I could prep the grille? Thanks
mgkgmc is offline   Reply With Quote
Old 02-06-2012, 07:44 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Painting a GMC grille
I would use a scotch brite pad first to scuff the chrome in those areas that will black again, then wash. Let dry, tack rag it, mask everything off that you want chrome still. Then I would spray some bulldog adhesion promoter to the area of black. Then follow up with a an etch primer, followed by black. If you skip the etch primer, make sure you definitely fog some coats of adhesion promoter before the black. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-07-2012, 09:23 AM   #3
On a nice grille I'd follow all of Trevor's advice. I wanted to freshen up my'72 grille when I got it back in '01. The grille is dulled and someone used roofing staples to fasten screen behind the openings,leaving little snake bit marks all around there. I scuffed with steel wool,masked,and sprayed satin black and it has held up nicely. I also did the headlight doors,leaving the outer rim chrome,because they had some pitting and were badly tarnished:
Old 02-07-2012, 09:45 AM   #4
mgkgmc
mgkgmc's Avatar
That looks great that's exactly how I want mine to look.
