02-06-2012, 07:30 PM | #1 |
Location: Hickory, NC native, but stuck in Valdosta, Ga
Staggard or What?
Should U do staggard or even all around? 20's of course! Why or Why not?
02-06-2012, 07:45 PM | #2 |
Re: Staggard or What?
This is the rim I like! If U have these already what is the back space and any other info I need to know!
https://www.tiresbyweb.com/p-8046-bo...me-wheels.aspx |
02-06-2012, 07:46 PM | #3 |
Also like this color too:https://www.tiresbyweb.com/p-8047-bo...ey-wheels.aspx
02-06-2012, 07:57 PM | #4 |
IMO Ive always liked the staggered look. Thats what Im doing on mine. It gives it that muscle look. And you gotta love that huge lip on the back set! The only reason I personally would consider doing a non staggered setup would be that you can rotate the wheels around to prolong tire life. Id go staggered on your expensive rims and keep the regular stockers for winters and long trips.
02-06-2012, 08:00 PM | #5 |
67-72 parts collector,…
There is a TON of info about the Boss 338 Wheels on here.
I like the wider wheel on the rear of the truck,... because the rearend has a narrower "track width" than the front wheels.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-06-2012 at 08:59 PM. |
02-06-2012, 08:57 PM | #6 | |
Didn't think of this! To many years in the Air Force! I like this idea!
02-06-2012, 08:59 PM | #7 |
Like this info Also! I'm going to look up what other's have done, with th Boss 338's!
02-06-2012, 09:19 PM | #8 |
Ok toooo many 338 posts, kind of a pain to look! Please tell me or show me what U have?
02-06-2012, 10:13 PM | #9 |
Formerly- 1972SuperCheyenne
Staggered because it looks better! Who cares if you cant rotate them front to back. Buy tires that are A-Symetrical and not directional and you can rotate them side to side if you wanted to.
20x8 5.25 backspace, 255/40/20 20x10 5.5 backspace, 295/40/20
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
02-06-2012, 10:28 PM | #10 |
Have You seen the 275 x 50 x 20/ 20 x 8.5 and 5.25 back spacing? Will the tires be taller ?
02-06-2012, 10:41 PM | #11 |
If you're not going to lower it(I think you should!) then dont do staggered wheels. They wont look right on a stock height truck.
