Old 02-06-2012, 09:16 PM   #1
Handfull 54
Handfull 54's Avatar
Modifying Fat Man Crossmember
I was told by the people at FatMan that I could use a 79-90 Mustang R&P by elongation the holes on the passenger side. I was told just to elongate the inboard side. Has anyone done this and what type of grinder would you reccommend? I was thinking of one of those grinders used to port cylinder heads. My power rack is from a 74-78 Mustang II. I have a big block in my 54 pick up and it steers like a go kart. Iv'e only got 500 miles on it and I did have the pressure reduced in the steering pump but it is still too quick for me. Also has anyone used a manual rack with a big block? My crossmember was bought back in the late eighties and drilled only for the 16" on center rack. Thanks in advance for any help.
Handfull 54 is offline   Reply With Quote
Old 02-06-2012, 11:40 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Modifying Fat Man Crossmember
I have no experience with that application but I will offer some input. Any time I adapt an oem component I try to avoid modifying the component. My theory is I would rather keep the part original in the event I need to replace it . I prefer to mod piece that the part is attached to when possible.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-07-2012, 01:12 AM   #3
Handfull 54
Thanks for the input. I was told to elongate the crossmember, not the R&P. He said there soon will be no parts for the 74-78 Mustang II. When was the last time you saw one? If I modify the crossmember I can use a newer R&P with better steering and parts that will be around awhile.
Old 02-07-2012, 02:11 AM   #4
PBFAB.COM
PBFAB.COM's Avatar
Can you cut the mounting tab off the crossmember and move it over 1/2 an inch then re-weld it in place?
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-07-2012, 02:38 AM   #5
andrewmp6
I doubt they will quit making mustang 2 parts,Look at how many companies make stuff for the suspension let alone sell it as a kit for just about any old car or trust.I would talk to flamingriver or unisteer they both sell racks for it just tell them what its in and you have a big block.
andrewmp6 is offline   Reply With Quote
Old 02-07-2012, 08:36 AM   #6
Handfull 54
Hello Porterbuilt. My cross member is from when Fatman first started out. The crossmember has no tabs just two holes drilled in the crossmember. It's like a piece of 4x4 wood with two 1/2" holes in it 16" center to center.
Andrew None of those companies have what I want with a !6" center to center rack. They could probably make one but it would be very expensive as a Flaming River power rack is close to $800. The 79-93 power rack with a 20:1 ratio is what I want and they are 15 1/2" center to center. Rebuilt ones are $180-250.
Thank you both for your input, but Somehow I have to make the hole on the passenger side 1/2" longer toward the center.
Old 02-08-2012, 04:18 PM   #7
robnolimit
robnolimit's Avatar
I have weld-on rack mounts for these. (so does fatman's) they run $24 pr. the drivers side will go right over the OE mount hole, the pass side will move in 1/2". The rack does move forward appx 1" when you do this. Steering is fine, steering shaft connection may need to be changed.
The Flaming River Billit rack uses a clamp on mount on the pass side, it will bolt right up to your crossmember. PM me if you need a price on that rack.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 02-08-2012, 05:29 PM   #8
49studebaker
49studebaker's Avatar
I am running a manual R&P out of a junkyard Mustang II in my 49 Stude. When I ran the 427 BB in the truck I had no problems at all. I have a smaller steering wheel and only when I was not rolling was it a bit tough. I really liked the feel of the manual once I was moving. Manual rack/no cup holders, impossible to cruise with a beer in hand!
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
