Old 02-06-2012, 10:07 PM   #1
sigshooter
sigshooter's Avatar
What are these called, fender splash shields?
These go on the top edge of the front fender, under the corner cowl of the cab. I am guessing they were added by GM to help keep dirt and mud from splashing on up into the cowl area and on into the door jamb..... My guess. Does anyone know what they are called for sure and some of them had adhesive on the bottom where a rubber weatherstrip might have been attached, some don't.
someone who knows about these please educate me with all the info you have about them. Not all trucks I have torn down have had these only a small percentage so I am thinking they were added after the vehicle was built, like a recall or something. Once again someone help me out here
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 02-07-2012, 12:08 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: What are these called, fender splash shields?
Just pulled one off the fender on my 'burb. My other trucks dont have them and I have no idea what they are called.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-07-2012, 01:35 AM   #3
Captainfab
60-66 Nut
I don't know what they are called either. I can see how they would reduce the mud and water under the cowl corners and running down the fenders. I just pulled a fender from a '62 on Sunday, that appeared to be original, and it did not have those. I believe this is the first front fender I have had my hands on that did not have one of those on it.
Old 02-07-2012, 09:05 AM   #4
sigshooter
sigshooter's Avatar
It is hit and miss with no rhyme or reason that I have found whether they have them or not. I have found them on 1/2, 3/4, 1 tons, even 2 ton trucks.
Now even time I get one in the scrap yard I take the cowl off just to see if this truck has them or not.... it has become an Easter egg hunt for me
Still searching for answers
1966 Short stepside
1964 long bed
Old 02-07-2012, 09:21 AM   #5
scottofksu
scottofksu's Avatar
My 65 has them, but only the driver's side had the rubber "glued" to it...
scottofksu is offline   Reply With Quote
Old 02-07-2012, 03:00 PM   #6
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
just saw this over on ChevyTalk:
http://www.64moneypit.pages.qpg.com/...ucks/id76.html
Larry
fleetsidelarry is offline   Reply With Quote
Old 02-07-2012, 03:14 PM   #7
dtkarst
All of the parts trucks and my 66 that i drive have them, along with my brothers 63 I just figured they were there on all of them.
dtkarst is offline   Reply With Quote
Old 02-07-2012, 03:17 PM   #8
Max1775
Max1775's Avatar
My 66 doesn't have them...
Max1775 is offline   Reply With Quote
Old 02-07-2012, 09:51 PM   #9
sigshooter
sigshooter's Avatar
Originally Posted by fleetsidelarry View Post
So, GM call it a "filler"....... interesting. Still wondering why some trucks have them and some dont. Not all of them I have had the rubber seal glued on the bottom, even more interesting.
Maybe someone else will chime in with even more info. At least I know what they are called and GM actually had a part number listed for them.
1966 Short stepside
1964 long bed
Old 02-07-2012, 10:21 PM   #10
64fleetside
I'm sure bodymen tossed many aside over the years when replacing fenders, but I had one early 64 that had no trace of them, and some of the top pieces have seals stapled, some have glued seals, some have no seal.
64fleetside is offline   Reply With Quote
Old 02-07-2012, 10:50 PM   #11
jbgroby
jbgroby's Avatar
I had them on my '60 and will put them back. Who knows it may be the one piece that holds the whole front end together.
jbgroby is offline   Reply With Quote
Old 02-07-2012, 11:39 PM   #12
'63GENIII
'63GENIII's Avatar
Now I have to go look at mine. If it doesn't have them, could mean that it was built on a Friday around quittin' time
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 02-08-2012, 02:46 AM   #13
suzq044
Resident Photoshop Nerd
suzq044's Avatar
mud flaps.. before they went all rubbery.. lol
PJ - 1966 C10 Panel --
Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn
suzq044 is offline   Reply With Quote
Old 02-08-2012, 10:12 PM   #14
protrash64
protrash64's Avatar
I noticed on one truck the 2 holes for the sheet metal screws but the filler was long gone.....maybe you have it sig.
