350 or 700r4? Which Transmission ??
350 or 700r4?
Im trying to put a drive train together. I have a stock SB350 going in, and a THM350 as well. Im wondering if I should just go withe the 700r4. Id like to be comfortable on the highway as well. I havent bought a rear end yet either. What do you guys think. Do I really need the 700r4 or will my 350 be just fine? Thanks in advance!! 52 3100 |
Re: 350 or 700r4? Which Transmission ??
700r4!
1959 Chev Apache 3100 Short Fleet Big Window ![]() |
I have a 700r4 for my truck
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
Elev8r Man
Either tranny is good in it's own respect as to what your looking for it to do. I prefer the 700r4 because of my rear gear ratio, and want to just cruise on the freeway and not rev my engine high like with the TH350. I checked to see which is more cost effective to change and the tranny was cheaper.
1955.2 C4 Carry-all / Suburban ![]() 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
Thanks guys, Im leaning towards the 700
Remember that the 700 is an overdrive trans, with T/C lock up and 4th gear electronically controlled. Be sure to either get one that has been converted or pop for the conversion kits.
Curly |
Overdrive all day long. Do whatever it takes.
I have a overdrive trans in my '65 mustang, and don't know how long I will be able to keep the 4spd manual in my pickup when I start driving it more. the benefits of that extra gear are tremendous. If your not hot on top speed you can drop your gear ratio for better acceleration, or just enjoy cruising at 65mph at something like 2300rpm use the technology and spend the money now if you can afford to, you won't be sorry later
1955 2nd Series 3100 - 400 Pontiac / BW Super T-10 4-Speed 1972 K5 Blazer 350 Auto 4x4 1928 Ford Model A Tudor Last edited by Maximus; 02-07-2012 at 02:23 AM. |
i agree with all above - 700r4 - i am running that also - all internals are corvette - ( got a killer deal on that )
Just make sure that your overdrive tranny will match your rear gearing.
![]() Join Date: Jul 2006
After swapping several 700's, I like them BUT you never feel as confident about flogging them like a TH350 or TH400. I hear this from alot of guys, even though our 700's are built.
My '71 has some power and lately I've been wishing that I had stuck with a TH350 and re-geared to 3.08.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
Another way to go is this, http://www.hotrodders.com/forum/1969...r4-154994.html
http://www.nwccc.net/garage/Easy_Overdrive.htm
Retired and too busy to work. Last edited by oldcouple; 02-07-2012 at 12:24 PM. |
4th gear isn't electronically controlled. the wiring is just for the torque converter lockup and can be wired with a switch and a relay. no expensive kit needed
#13 |
get the OD trans and a rear gear gear in the mid 3.xx range. Best thing you can do.
#14 |
![]() Join Date: Sep 2011
Have to agree with most everyone. Hard to beat a 700 R4 because of the overdrive. Especially if you are going to cruise any distance. Before you go either way also look at you motor(mild or wild), rear end ratio, tire size,towing,budget, and as mentioned above what your main intent is.How many miles a year will you drive. Do the math in fuel savings. Don't rule out the 400. If someone gives you a rebuilt 350 you can buy a lot of fuel over rebuilding a 700 R4. If you find a deal on a rebuilt 700R4 well worth the little fiddling with the overdrive stuff. All three trans will work fine. Just pick the one that best fits your app ,budget, and goal. Good luck.
#15 |
700r...it gives you overdrive.
Posted via Mobile Device |
#16 |
Certified Car Nut
#17 |
The password for cool '90s street performance is...overdrive. Late-model automatic and manual overdrive transmissions are quickly becoming the sweethearts of the street set. Not that long ago, a fast street car meant compromises, including deep gears, high-rpm highway cruising, and poor mileage. But the high-tech '80s and '90s have brought us more than just electronic fuel injection. They also delivered durable automatic overdrive transmissions.
While the TH700-R4 has garnered most of the attention as the performance automatic overdrive of choice, companies such as TCI and Art Carr consider the TH200-4R every bit the 700's equal in terms of torque capacity and durability. There are several advantages to the TH200-4R: It has a better First-gear ratio, it's generally the least expensive overdrive automatic, and best of all, it's virtually a bolt-in replacement for Powerglide/TH350 transmissions.
Retired and too busy to work. |
#18 |
The only bad part of the 2004R is that it is not plug-and-play. if you don't know how to set one up, you could burn one up very easily.
#19 |
Certified Car Nut
#20 |
Thanks for the info
Ok working on getting a 700 right now. The freshly rebuilt 350 will hang out until someone needs it. On a side note, Ive only seen transmission brace kits from places like CPP and Chevys of the 40's for TH350 transmissions. Nothing for a 700r4. I know the 700 is 3 inches longer. Can I use the same brace and scoot it back 3 inches. Do I need to modify a 350 brace? Is there a 700r specific brace? Any links to a 700r4 47-53 build threads?? Im working with a 1952 3100 Thanks, you guys are great!! |
#21 |
same tranny mount as the th350, just sits about 1 inch further back. same gear selector linkage too
#22 |
After some research, Im getting a 700r4 put together right now from Dana Sniff out of Irvine, CA. This guy knows his stuff, hes been in the business for a long time.
Bowtie overdrives has the perfect TV cable carb adapter kit too. I think im good to go in the transmission dept! |
