Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 02-06-2012, 11:55 PM   #1
GMCNUT
GMCNUT's Avatar
Wtb 1960-1962 factory power steering
Hey guys - I know I asked about this before, but need to refresh everybody's memory that I need to find a factory slave cylinder style power steering setup off a 1/2 3/4 or 1 ton 60-62 chevy or GMC torsion bar equipped truck.
60-62 is basically the same as 63-66 but has a bent drag link instead of the straight 63-66 style, and the cast iron bracket bolted to the drivers side of the boxed 60-62 frame used to support the push rod is a relatively flat triangle shaped bracket vs the much wider dog leg 63-66 cast bracket used on the 63-66 C-channel framed trucks. (See attached pictures)
GMC's came with power steering a lot more often that Chevrolet's, and it can be found on suburbans and panels fairly often.
If anyone can produce a lead to one of these setups, I am happy to pay a finders fee too....please let me know what any of you can dig up for me....
Thank you!
GMCNUT is offline   Reply With Quote
Old 02-07-2012, 10:52 PM   #2
DPowers
DPowers's Avatar
Re: Wtb 1960-1962 factory power steering
pm sent
DPowers is offline   Reply With Quote
Old 02-26-2012, 01:41 AM   #3
GMCNUT
GMCNUT's Avatar
Still searching for a 60-62 factory power steering set up and also need 60-61 inner fender mounted power brake setup too....Thanks!
