Old 02-07-2012, 01:04 AM   #1
mr57
mr57's Avatar
Rad and m/c questions
I finally got around to doing some work on my 64 swb panel and yanked the rad and master cylinder I know the front clip was swapped out for a GMC sometime in the past, but when I pulled the rad I noticed it was still in the 6 cylinder position. The bottom mount for the V-8 is still there, but the top plate is missing. This isn't a big deal, really, as I can find a V-8 top piece fairly easily, and/or get a shroud if needed.
The question comes in with the rad. I stripped out the drain bung and need to get it repaired, plus get the rad cleaned and pressure tested. If our rad guy can't repair it or it blows apart, is there any difference between a 6 cyl. automatic rad and a V-8 auto rad??
Next question deals with the m/c. The parts guy I talked to says there are four different master cylinders listed in his computer for 1964. It's the fruit jar style, not the square one, for a factory V-8 auto truck. Any idea what the part number should be?? Or am I going to have to rip it apart and measure the bore to find out??
mr57 is offline   Reply With Quote
Old 02-07-2012, 01:09 AM   #2
dugvera@gmail.com
dugvera@gmail.com's Avatar
Re: Rad and m/c questions
I know guys are having luck with an inexpensive aluminum radiator found on ebay. Thinking about one myself.
Doug
66 4x4 GMC Suburban
76 4x4 Chevy Shortbed
dugvera@gmail.com is offline   Reply With Quote
Old 02-09-2012, 01:03 AM   #3
mr57
mr57's Avatar
Bttt. Anyone??
Old 02-09-2012, 01:09 AM   #4
DanSan c 10
DanSan c 10's Avatar
I just spent $380 on a new aluminum rad for my 6 and had to move the bottom mounts closer together. Cool craft rad. I would think the v8 would be a little bigger. But should be almost the same.
Why can't I find it until the last place looked?
65 Longbed 283 three on the tree.
66 Longbed 292 three on the tree.Pennys A/C
Trucks made in USA
Buy a much as you can, Made in the USA
DanSan c 10 is offline   Reply With Quote
Old 02-09-2012, 11:58 AM   #5
Rich 5150 69
Rich 5150 69's Avatar
Champion rad alum 3 row, nice fit, $230 delivered to my door.
http://www.championradiators.com/page/407019730
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 02-09-2012, 12:58 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
^^^^ that is what I have, keeps my LS very cool. My dad has one in his crew cab also
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
