Old 02-07-2012, 08:57 AM   #1
ryanroo
ryanroo's Avatar
Body bushings
I need to buy some new cab bushings and core support bushings. the truck is a 72 but i am using a 67 clip.
i see that 67-68 are listed differently and i was just wondering if the difference is in the frame or the core support. do i need to use the 67 bushings or the 72?
what is everyone's opinion on rubber vs. poly?
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 02-07-2012, 02:41 PM   #2
Hellbent
Don't blame the messenger
Hellbent's Avatar
Re: Body bushings
I have a 69 with a 67 clip and I just replaced the cab bushings and core support bushings. Right or wrong- I used 69 bushings on the cab and 67 bushings for the core support. No issues yet. I will have to admit- changing those cab bushings were by far the easiest "fix" I have done on this truck. I went with rubber- It's a street truck, my thinking -why go poly if it will never touch dirt... In your case and you offroad- maybe you should consider poly.
On the Level
Just a guy with a hammer and a grinder. OH!, and an HOA- enough said...: http://67-72chevytrucks.com/vboard/s...d.php?t=372525
"Some drink from the fountain of knowledge while others just gargle."
Hellbent is offline   Reply With Quote
