Old 02-07-2012, 09:01 AM   #1
DirtRocket8x
Question who has built ccsb
For those who have build a ccsb i started mine on my 86 are y'all using the 4 center bed holes and then sectioning the front piece 2 use the factory front hole then cutting and re drilling the back ones any imput would b appreciated
DirtRocket8x is offline   Reply With Quote
Old 02-07-2012, 09:53 AM   #2
rs72z
rs72z's Avatar
Re: Question who has built ccsb
Sorry i havent had a chance to call you. The first cut needs to be behind the front bed bolt hole, the front and next to last holes will line up. Then you will have to drill the other two sets.
I measured back from the rear cab mount crossmember i think it was 7 1/2", that should put you just about a 1 1/2" behind the front bolt hole.Let me know if you have any other questions.
Paul
rs72z is offline   Reply With Quote
Old 02-07-2012, 10:00 AM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I did mine the same way. Measured back 7 1/2 or so and made my first line. That way the factory frontmost bed hole is still in the original location and I dont have to worry about the bed not lining up right with the cab.
--Josh
Old 02-07-2012, 08:58 PM   #4
DirtRocket8x
Thanks I know ur busy do just before I go attempt this I wil be using the factory front hole in the frame and when I cut and weld it back together then the first 6 Will all b factory holes in the frame only the rear 2 will b redrilled
Old 02-07-2012, 09:10 PM   #5
STOCKISH
STOCKISH's Avatar
I dont have the bed back on mine but I think the front 4 will line up and drill the rear 4. Either way, as long as the front 2 are factory at least the bed will line up with the cab properly.
--Josh
Old 02-07-2012, 09:20 PM   #6
DirtRocket8x
I had the bed sitting on mine with the 4 closest around the rear end in the holes just the front and back 2 wasn't there
Old 02-08-2012, 08:28 AM   #7
rs72z
rs72z's Avatar
Unless something is diffrent only the front 2 and the next to last 2 should line up. That's the way mine is. When you take the 3 1/2" off the rear you lose the rear hole and you lose the second set from the front when you take the 14" out.
Old 02-08-2012, 08:30 AM   #8
rs72z
rs72z's Avatar
Have you cut yours yet?
Old 02-08-2012, 08:32 AM   #9
DirtRocket8x
No just getting ready 2 lay it out
Old 02-08-2012, 08:35 AM   #10
rs72z
rs72z's Avatar
Post some pics after you lay it out if you have any questions. I might can get away to run by Sat. or Sun. before you cut it if you need me too.
Old 02-08-2012, 08:50 AM   #11
DirtRocket8x
Ok thanks I appreciate the help
Old 02-08-2012, 07:25 PM   #12
DirtRocket8x
how much overlap are yall getting i can get 4 inches without moving the spring hanger
Old 02-08-2012, 11:11 PM   #13
rs72z
rs72z's Avatar
Are you talking about where the z cut will meet?
Old 02-09-2012, 04:50 AM   #14
DirtRocket8x
Yes
Old 02-09-2012, 10:16 AM   #15
rs72z
rs72z's Avatar
I cut mine 3" to leave room for a fish plate without getting into the hangers.
Old 02-09-2012, 10:34 AM   #16
DirtRocket8x
Ok thanks
