Old 02-07-2012, 12:36 PM   #1
brak
brak's Avatar
6 lug rims
Hey guys, i've been gone for a while, but here's a question...
I turned my old Long bed and frame into a trailer, using a 6 lug axle i had laying around, but i've had trouble finding wheels that will fit, due to the large hub.
I think these will work, but confirmation would be appreciated.
Series: Cragar Delux 69
Wheel Diameter: 15 in.
Wheel Width (in): 6.000 in.
Wheel Material: Steel
Backspacing (in): 3.500 in.
Offset: 0.00mm
Wheel Construction:1-piece
Lug Nut Seat Style: Conical seat - 60 degree
Hub Centric : No
Center Bore Diameter (in): 4.280 in.
Center Bore Diameter (mm): 108.71mm
*STOCK PHOTO*
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 02-07-2012, 12:48 PM   #2
dubds10
Stalker Nate
Re: 6 lug rims
Not sure on the hub sizes but I know they are larger than most newer rims, but if you have some steelies already, just bore the center hole out more. Take a dremel to it and go to town. Done that a few times with steelies to get them to fit since they aren't hub centric anyways.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 02-07-2012, 01:05 PM   #3
brak
brak's Avatar
Re: 6 lug rims
Yeah, I have a couple rims from a 90's k1500, and started doing that, but ALOT of material has to be removed, which proved to be way more work than it was worth.
Old 02-07-2012, 04:40 PM   #4
rsavage
rsavage's Avatar
Re: 6 lug rims
The rim in the photo is a five lug. You are looking for six lug correct? Truck rallyes from a 73 and up will work. You can buy them on Craig's list for $20 - 25 each. Clean up and a coat of paint and they look pretty good.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-07-2012, 04:57 PM   #5
brak
brak's Avatar
Re: 6 lug rims
I'm done searching for rims locally. i've spent almost 2 years looking, with no luck.
I'm out of time so to speak, i'm going to pull the trigger, and buy a set.
i just wanted to verify the backspacing and center bore are correct
The rims in question are 6 lug, the photo is just a "stock photo" cragar had on their site.
