Old 02-07-2012, 03:51 PM   #1
jwgeorge
Oil Under Distributor Cap
OK, I have motor oil coating everything undcer my distributor cap. Is it most-likely the inner distributor seal? It's a 250 6-cyl. with XXX miles on it. Anyone had this problem? Thanks!
1968 C-10 Longbed, 6-cyl., 4-speed.
832-584-1245
"You see, in this world there's two kinds of people, my friend, those with loaded guns and those who dig."
jwgeorge is offline   Reply With Quote
Old 02-07-2012, 04:00 PM   #2
cdowns
cdowns's Avatar
Re: Oil Under Distributor Cap
do you have a proper PVC system on your engine// pressure makes things leak at the point of least resistance
Old 02-07-2012, 05:26 PM   #3
yuccales
yuccales's Avatar
^This^ Plus your shaft bushings may be worn out allowing oil to slip on by.
yuccales is offline   Reply With Quote
Old 02-07-2012, 06:30 PM   #4
jwgeorge
I have a new PCV valve and a good breather cap, well, I assume that everything is good. PCV valve mounted in valve cover, connected to vacuum stub under carb and oil breather cap on front of valve cover. Aftermarket chrome valve cover, so I assume that provides for proper circulation.
How does the factory PCV system connect?
832-584-1245
Old 02-07-2012, 09:38 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I had some in mine when I got it.An HEI solved that and got me better milage,starts,and smoother running.Cost me abot $40-50 with the new wires and plugs.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-08-2012, 10:10 AM   #6
jwgeorge
Gosh, I hate give up my points distributor because it's so fool-proof, but an HEI would be nice. Do I just need a dizzy from a 74-on 250?
832-584-1245
Old 02-08-2012, 10:36 AM   #7
jwgeorge
OK, I just figured-up what it would take to convert to HEI, getting all parts at AutoBone.
For a reman HEI dizzy, w/module, no cap or coil - $92.00, not too bad.
But then I added up everything else I would need, cap, coil, plug wires, plugs and of course, spare module. Grand Total: $199.00.
I can get a reman points dizzy from AutoBone for $38.00 and I have all the peripherals.
For the cost difference I think I can make it run almost as nice as an HEI by setting the gap and dwell carefully and setting the vacuum by adjusting the carb mixture.
As much as I like HEI, that $150 saved would probably be better spent somewhere else on this old truck.
832-584-1245
Old 02-08-2012, 10:39 AM   #8
PanelDeland
I paid $25.00 for the HEI at the JY and got lucky that everything worked on it.I probably got lucky since everything on the dist worked and the cap was nearly new.I've since changed it.
