Old 02-07-2012, 06:09 PM   #1
Sicboy
Sicboy's Avatar
Clutch...What brand & size?
I need to replace the clutch in my '66 with a 327 and saginaw 4 spd. What brand do you recommend? Are Rhinopac clutches any good? Currently, i have a 12" clutch with a 168 tooth flywheel. Should i stay at 12" or drop down to an 11"? I dont drive that aggresively...burn out every once in awhile.
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482
Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!”
- Hunter S. Thompson
Sicboy is offline   Reply With Quote
Old 02-07-2012, 06:25 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Clutch...What brand & size?
Mine is a 350/Richmond 4 speed and I’m running a 10.5” clutch and it works fine. I wouldn’t go through the expense of changing sizes from one to the other unless there’s a specific need for it. And I wouldn’t recommend any performance clutch unless you’re going to really beat it up. My experience has been they tend to chatter more than a stock plate unless provided abundant rpm at launch.
I’m running a Centerforce 1 and I wouldn’t recommend it either for something driven daily. The centrifugal weights unique to this brand tend to rattle when they’re floating during shifts, which I find very annoying. When mine wears out I plan to buy the best premium stock replacement clutch Napa Auto offers
Old 02-07-2012, 06:42 PM   #3
Sicboy
Sicboy's Avatar
Ha, I was just looking at NAPA's website. I'm not sure if the previous owner installed a larger clutch than stock. No parts house lists the 12" as a stock clutch on a '66. The flywheel accepts both 11" and 12". I read somewhere on this forum that a 12" is harder on the synchros and harder shifting than an 11".
I'm about the NAPA NCF 1104072 clutch and the NCF 88101 flywheel. BTW, my flywheel needs to be replaced due to cracks.
Old 02-07-2012, 07:24 PM   #4
Greg63
Enjoy your truck
Greg63's Avatar
I am running a Centerforce and really like it.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 02-07-2012, 09:17 PM   #5
T Smith
T Smith's Avatar
When I built my new engine I picked up a new "car" flywheel and was planning to do the swap to 11" but the old 12" flywheel was fresh and so was the clutch so I just kept it 12" which is what I thought was stock.
T Smith is offline   Reply With Quote
Old 02-07-2012, 09:48 PM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I have used Centerforce clutches before without problems. My '65 C10 I used a Ram "Muscle Car" clutch. I thought it might have a heavy pedal feel but it actually felt softer than what was in the truck before. It holds great though. Would use them again. Picked it up from Summit Racing.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
