Old 02-07-2012, 08:23 PM   #1
dujobu
Driveshaft disassembly help needed
To all you seasoned veterans out there…I need some tips on disassembling my driveshafts so I can clean them up and replace some worn parts. I got the snap rings off. Now what? How do I free the cross from the unit? Any advice is much appreciated. Thanks for your time.
dujobu is offline   Reply With Quote
Old 02-07-2012, 08:40 PM   #2
airdale94
airdale94's Avatar
Re: Driveshaft disassembly help needed
You will have to press or hammer them out. A ball joint press will work. Or a hammer and a socket and a vice. Might need some heat or penetrating oil.
airdale94 is offline   Reply With Quote
Old 02-07-2012, 08:40 PM   #3
JimKshortstep4x4
A good 6" vise will work for most of the u-joints. I use two sockets one for pressing against one of the bearing cups and a larger one to allow the opposite bearing cup to go into. Soak the u-joints down with a penetrant ahead of time so that it will help loosen the cups.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-07-2012, 09:33 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Have I got a vid for you.This never goes quite this easy but this is a good vid on How to.
http://www.powerblocktv.com/player/2...ep_num=2min-06
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-10-2012, 03:38 PM   #5
dujobu
Thanks so much guys. And that video…perfect.
Old 02-10-2012, 11:01 PM   #6
bollybib
bollybib's Avatar
I wrote this up a while back. It might help you.
http://67-72chevytrucks.com/vboard/s...d.php?t=492271
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 02-11-2012, 12:27 AM   #7
dujobu
Perfect! Thanks Jim.
