Evaporator housing seal?
I removed my leaky A/C evaporator housing in an attempt to reseal it (leaks every time it rains). I've gotten it all cleaned up, but now I need to reseal the two sides and remount them to the firewall. What product should I use to create those seals? RTV? Or is there a specific product for this?
Posted via Mobile Device |
![]() Join Date: Apr 2011
Re: Evaporator housing seal?
I just did mine up with some silicone adhesive seal. I made sure to put a thick bead on and just laid it up on the firewall. I dunno how it'll hold, but I did a search before I went to town on it, and that's what people were recommending
-Steve ![]() 1980 GMC C15 Sierra LWB Dark Carmine Red/Carmine Int Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011) Now: 5.3/4L60E, 2.73 12-bolt open rear |
Did you use the same stuff to join the two halves of the box?
I went to oriellys and got a role of ribbon strip like they use for installing windshields in early cars. Worked great. Just stretch it to the diameter you want. It is real close to what they used originally.
The box already came sealed, looks like they used a rubberized adhesive (probably similar to the silicone adhesive I used)
Robert Olson Transport
![]() Join Date: Oct 2002
they used RTV Black silicone on mine when it was done last
I believe the factory used 3M "Strip Calk" (that's how it's spelled). You can ask for this stuff by name at NAPA..but I think you can get it at pretty much any auto parts store.
It comes in a box & it's basically 12 inch long strips of black, sticky, claylike stuff that you just push into place. Theres a string in the middle of it to keep it from breaking apart. Really easy to work with. It doesn't ooze out & make a mess of things either.
J ![]() |
J ![]() |
You guys rock - thanks! Maybe I can finally close up that huge hole in my firewall now!
do you use this same stuff to wrap around ends where connections come thru to accum and hose?
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
#11 | |
Thanks, installed a new evaporator today and used the 3M stuff, boy that stuff is sticky. Kinda pricey at $23 from oreilly but they give you plenty.
