Old 02-08-2012, 02:54 PM   #1
OLDIRON69
'05 2500HD Cluster issue
I know these trucks have issues with the gauges but mine is the tach only. It pegs the tach doing 40mph in overdrive.Sometimes it works fine. Where does it get it's signal from? All the rest of them I have seen with problems have had fuel gauge issues or something other than the tach.. Any input would be great.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 02-08-2012, 07:15 PM   #2
clinebarger
Re: '05 2500HD Cluster issue
Its the stepper motor, Ive seen EVERY combination of gauge malfunctions on these trucks.
The PCM sends a (2 pulses per engine revolution) engine speed signal on a dedicated curcuit to the IPC.
clinebarger is offline   Reply With Quote
Old 02-09-2012, 09:14 AM   #3
OLDIRON69
Easy fix or replace the cluster?
05 2500HD 6.0 excab
Old 02-09-2012, 09:50 AM   #4
truckdude239
truckdude239's Avatar
dorman products offers reman gauges with a life time warranty they come preprogramed with your vin and mileage in the just bolt in and go, only down fall is the core charge on them is $300 dollars which you get back when you take the old one back the clusters normall run 240-300 dollars, i order them from advance auto parts, they have to call dorman to order them if they say they cant
http://www.dormanproducts.com/gsearc...&type=parttype gas engine
http://www.dormanproducts.com/gsearc...&type=parttype diesel engine
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-09-2012, 09:58 AM   #5
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
If you are handy with a soldering iron it is an easy fix. Usually you can send it off for a week or two and get it fixed for under $100, but you will be without a cluster for that time. Or as truckdude has mentioned you can buy a reman cluster and send yours in as a core. Make sure you get it preprogrammed, otherwise it is $80 at the dealer to program your mileage. There are quite a few reputable dealers on Ebay that can get you a stock replacement preprogrammed cluster for under $200 that were around before Dorman started selling these clusters a couple years ago.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 02-11-2012, 09:22 AM   #6
truckdude239
got to have a user name and password to log inot that place 1949
David fuller
2000 Tahoe 5.3l 378
