Old 02-08-2012, 06:32 PM   #1
sox8145
350
whats up guys? Imdoing somw work on my 350 in my 85 swb. Im gonna change the cam and was wondering what size to use and waht brand. i just want something mild the motor is boerd 30 over. also should i go with vortec heads or just the regular ones i have now
sox8145 is offline   Reply With Quote
Old 02-08-2012, 07:40 PM   #2
74 stepside
74 stepside's Avatar
Re: 350
Call Comp Cams and ask to speak to a tech. They are very helpfull and knowledgeable. Tell them engine size, trans, converter, and what you are going to use the truck for (towing or cruizing,etc.) Just google them for their number.
74 stepside is offline   Reply With Quote
Old 02-08-2012, 10:51 PM   #3
slugish
Slugish
Re: 350
x2
slugish is offline   Reply With Quote
Old 02-09-2012, 08:27 AM   #4
BigBlocksRule
Re: 350
BALONEY!!!
Call Comp 4 times, you'll get 4 different techs and 4 different answers. About half of those guys couldn't swap a cam if their lives depended on it.
Vortec heads will require an intake swap but will make a good bit more power.
If it's a daily driver, don't go too big on the cam. Fender shakers are impressive to listen to, but a royal pain to drive. I'd stick with something small, 224/230 is about as big as I'd consider if you need vacuum for brakes, etc.
BigBlocksRule is offline   Reply With Quote
Old 02-09-2012, 01:36 PM   #5
Tucson38
Re: 350
Regarding the cam: First determine what you want the engine to do and at what RPM.
Then pick your cam grind based on that. You'll want to include your differential ratio and tire height in your equations.
Tucson38 is offline   Reply With Quote
Old 02-09-2012, 07:01 PM   #6
sox8145
Re: 350
Thanks for the info guys ill be making an order next week
