Adding power steering?
Is if difficult to add power steering to a 1980 Chevy C10?
Besides buying a steer box & ps pump, what parts will I need to replace for this type of an upgrade? Is it better to go with stock parts or convert to rack & pinion? Thanks |
Re: Adding power steering?
I would use stock unless you plan on dragging the frame. You will need a box, pump, brackets for the pump, new belt,the lines, and possibly a new crank pully.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
Does the gearbox bolt up in same holes as the manual box?
Thanks |
Garage wrench
Yes, but you will need a new/different pitman arm.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
Sounds like it would be better to wait and buy a different truck that already has PS.
Thanks |
Its not hard at all. Just changed my 73 to power steering. I went to
pull a part and took all the stuff off one truck. Sold my old stuff on craigs list.
EVEN JESUS HAD A FISH STORY...JOHN 21: 6 and 11 Bass in picture is a 11.4 pound largemouth bass I caught March 13 2014 |
What did the parts set you back?
Thanks |
I can't remember now but you can go to pullapart.com and look up
all the prices before you go. You need..pump,box,brackets,hoses,pitman arm & belt Some times you have to change bottom pulleys on crank, I was blessed I didn't have to. Some of these hoses have different size fitting, that's why its best to get it all from the same truck
