Old 02-08-2012, 08:54 PM   #1
Big Al 63c10
I can't go past 60 mph on the freeway
Whenever I try accelerating past 60 my truck starts to vibrate & I hear a low humming noise I'm afraid to push it further, any ideas what it could be...?
Big Al 63c10 is offline   Reply With Quote
Old 02-08-2012, 09:02 PM   #2
maxwoof
Re: I can't go past 60 mph on the freeway
Tires and wheels in balance and not out of round?
maxwoof is offline   Reply With Quote
Old 02-08-2012, 09:18 PM   #3
GeorgeLeonard
My guess would be universals. Try accelerating up a hill and then on the downside, lift your foot off the gas pedal. If the vibration goes away while coasting, the universal or universals are bad.
GeorgeLeonard is offline   Reply With Quote
Old 02-08-2012, 09:45 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
I agree the most obvious possibilities are tires or u-joints. If the joints are good, it could also be the driveshaft is either bent or out of balance or you could even have an imbalance in the engine. If you have a long bed with a two piece driveshaft it’s likely the bearing in the center is the problem. They are frequently neglected far more than the end joints.
Once the vibration is eliminated, if the truck still won’t go fast enough the universal solution is to take a small hammer and break the speedometer glass. Turn the speedo needle all the way to the top and the vehicle will accelerate like a rocket! Rocky and Bullwinkle showed how to do it back in the 60’s.
Old 02-08-2012, 11:25 PM   #5
jbgroby
jbgroby's Avatar
You know pilots get the same effect right before they break the sound barrier, you sure you're only doing 60?
jbgroby is offline   Reply With Quote
Old 02-09-2012, 12:04 AM   #6
kyhunte89@hotmail.co
I wish my truck could go faster than 60...
2000 RCSB lowered and boltons
1964 GMC ton 305v6
1985 Monte Carlo v8 all o.e.
1989 240sx pignose coupe
2007 klx
kyhunte89@hotmail.co is offline   Reply With Quote
Old 02-09-2012, 12:23 AM   #7
SIR
SIR
SIR's Avatar
TAKE IT OUT OF 1st GEAR...
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 02-09-2012, 12:16 PM   #8
Big Al 63c10
Yup as soon as I let off the gas when I push it the vibration stops
Old 02-09-2012, 12:20 PM   #9
jimmydean
jimmydean's Avatar
My truck stock did about 58 unless it was downhill.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-09-2012, 06:45 PM   #10
jonathan-m
I rarely take mine over 55 even with no vibrations
Rockin' a '66 and loving every minute of it
jonathan-m is offline   Reply With Quote
