Fabricate till you "puke"
Time to bring the old longhorn into the 21st century
My parts truck is a wrecked 00 GMC Z 71, smooth running 5.3, with about 130000 on the clock. Also many good body parts left to sell! This is my 1st rodeo on the swap, so I am sure you guys can help(espec on the electronics). I am lookin foward to that 18-20 mpg , that the fuelie plays on the hyway.....but still will be rowin that 6 spd Richmond box. Sound like fun? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Re: Time to bring the old longhorn into the 21st century
Have you worked out the crank spacing issue for the GenIII/Richmond 6 speed?
Yes, Sound like fun! |
Yes, I think I have , Oreillys has a flywheel that is about .400 thicker & should run the old style press plate. It also requires a different pilot bearing(parts listed from Leevons build). I am not sure about the starter, with the cast bell....got some tear down before I get started(it cold here)
