What is it ?
Does anybody know what this thing is ? and how it works.
Thanks.
Brian. '70 GMCHEVY '51 chevy "tin woodie wagon" IF YOUR CONFUSED I'LL USE smaller WORDS! |
![]() Join Date: Oct 2009
Re: What is it ?
isn't that your egr valve? As for how it works, that would be classified as black magic...
Re: What is it ?
emissions? I belive it changed the timming under certain driving conditions
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
Re: What is it ?
It's an emission part, It went inline in the vacuum line to the distributer, I believe it retarded the timing to keep the engine from dieseling when shutting it off.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Re: What is it ?
Good answer.
Why can't I find it until the last place looked? 65 Longbed 283 three on the tree. 66 Longbed 292 three on the tree.Pennys A/C Trucks made in USA Buy a much as you can, Made in the USA |
Re: What is it ?
I didn't know what it was either.... I threw mine away.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
Re: What is it ?
Thanks guys, It was hooked up with my old carb, vacuum lines and all. The new carb vacuum lines I ran direct to the distrubutor and pcv valve, then plugged all others. Now I just have to find where the wires come from so I can eleminate them.
Re: What is it ?
People that like to guess should tell you they are guessing. It is a selenoid that controles the vacume advance on vehicles with transmision controled spark. It would also alow vacume advance if the engine started running too hot.
Re: What is it ?
I believe thats part of the TCS, transmission controlled spark system - a smog control. The vast majority of these I've seen referred to on the board were disconnected at some point in the distant past, including mine.
Those wires should run to a TCS relay under the dash by the fuse block.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
