Old 02-08-2012, 10:53 PM   #1
RdoubleU
RdoubleU's Avatar
Nate/Rob Need Advice : Porterbuilt and No Limit Product Mix
Hoping Nate and Rob can help out or Advise on the below:
I purchased the No Limit Panhard Kit and the Porterbuilt 2-Piece bolt in notch
Unfortunately from my initial mocking up of the setup it looks like the two pieces are going to overlap and interfere with each other
Below is what I am seeing, about a 1/2" overlap
Planning on working on it this weekend to get the stock rivets, bump stop etc off which will give me a better idea of exactly how much it will overlap but its definitely going to clear each other as is.
RdoubleU is offline   Reply With Quote
Old 02-08-2012, 11:01 PM   #2
RdoubleU
RdoubleU's Avatar
Re: Nate/Rob Need Advice : Porterbuilt and No Limit Product Mix
Now you can see from each company's instructions that they both have to locator hole in the frame (mine doesnt have this) but No limits kit uses the hole to center the bracket and in Porterbuilts you can see it covers about 1/4 of the same hole
Old 02-08-2012, 11:11 PM   #3
RdoubleU
RdoubleU's Avatar
SO I do not want to affect the strength or integrity of either piece
I'm thinking the panhard mount needs to be flush with the frame and possibly section the notch to clear the no limit bracket.
I know this wont let the notch sit flush but will it affect it that much as far as fitment elsewhere and the overall strength?
Hope the pictures make it clear whats going on and a solution can be reached
Thanks for the help
Either way both great look pieces
Old 02-08-2012, 11:52 PM   #4
RdoubleU
RdoubleU's Avatar
Had another idea since I've Been staring at the photos
Just hate to cut up Nates work
The lower notch holes are located farther inward so they should not be affected
But basically trim the rear of the notch and create two more holes to secure the upper notch like originally planned
and hopefully that would let the notch and panhard bracket bolt flush and clear each other
Old 02-09-2012, 01:24 AM   #5
54Caddy
GM Addicted
54Caddy's Avatar
why dont you cut the porterbuilt edges off and weld the no limit bracket to it. basically cut both pieces of the porterbuilt notch to fit the no limit bracket. weld the no limit brakcet to the first piece from the porterbuilt kit.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 02-09-2012, 01:58 AM   #6
PBFAB.COM
PBFAB.COM's Avatar
Hmmmm......
I would try and do most of the trimming on the edge of the panhard bracket rather than the notch. I don't believe that it would make the bracket unsafe if you trimmed it back a little and re-drilled the holes further towards the back.
Is there going to be any fitment concerns on the bottom of the frame? (I am not familiar with Rob's mount).
Worst case, maybe look into trimming a little of each?
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-09-2012, 10:34 AM   #7
RdoubleU
RdoubleU's Avatar
Originally Posted by porterbuilt View Post
Hmmmm......
Im not thinking there will be any fitment concerns on the bottom of the frame.
Robs lower mount aligns with the factory frame rail so the notch should clear that part (going to have to get the factory bump stop bracket off and get the notch down on the frame to be sure)
You thinking something like the below? Cut the bracket to fit as long as it doesnt affect the lower mounting holes and only clearance the notch as needed.
I didnt know how much actual pressure can get on that panhard mount and if the width of that bracket was for max strength
Old 02-09-2012, 11:55 AM   #8
PBFAB.COM
PBFAB.COM's Avatar
That is what I was recommending. The rear plate does add strength to the design, but it appears that it's more intended to be a locator rather than bear a whole lot of the load. The front gusset that ties into the crossmember will do that.
I would run it by Rob, as he is the designer and manufacturer of the panhard bracket... get his blessing first, and then whip out the cut-off wheel.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-09-2012, 12:18 PM   #9
98layinframe
98layinframe's Avatar
Simple! Cut both brackets on an angle... That way your not loosing any bolt holes on the notch, and only the top left hole on the panhard mount. Ya can drill another hole in both and move that one bolt if ya want. Won't mess with the top side at all and or bottom of either with no strength issues
98layinframe is offline   Reply With Quote
Old 02-09-2012, 12:24 PM   #10
RdoubleU
RdoubleU's Avatar
Nate
Thanks Nate, I PM'd Rob to check it out so hopefully he chimes in as well
Old 02-09-2012, 12:55 PM   #11
robnolimit
robnolimit's Avatar
I like the drawing. It's OK to cut our bracket down, and drill two new holes. I agree with Nate, the notch needs all the strength it can get.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 02-09-2012, 01:13 PM   #12
RdoubleU
RdoubleU's Avatar
Rob - So Since I dont have the frame hole for locating the outer frame bracket anyway, I should just let the lower bracket locate the frame bracket for me, cut drill and be good to go?
Old 02-09-2012, 05:21 PM   #13
robnolimit
robnolimit's Avatar
Yep. Fit the lower mount first, finger tight. Then match up the sideplate and mark the holes.
Old 02-09-2012, 06:37 PM   #14
RdoubleU
RdoubleU's Avatar
Thanks Rob and Nate for both of your inputs
Nate summed up my current game plan so ill see how it goes
run it by Rob,... get his blessing first, and then whip out the cut-off wheel.
Nate
Old 02-25-2012, 07:51 PM   #15
RdoubleU
RdoubleU's Avatar
Just following up for anyone who might run into the same issue
Followed Nates advice once I got the Notch cut and in place
Marked my lines and took the cut off wheel to it
Old 02-25-2012, 07:55 PM   #16
RdoubleU
RdoubleU's Avatar
After the cut the bracket cleared the notch but had the same issue BustedTruck had with the NoLimit bracket: http://67-72chevytrucks.com/vboard/s...d.php?t=493691
The lower bracket hole would miss the frame by about a 1/4"
Both of our trucks are 6cyl frames so maybe that is the issue vs the frame the bracket was designed on
Old 02-25-2012, 07:58 PM   #17
RdoubleU
RdoubleU's Avatar
Heres the final result : Filled in the locating hole and the lower bolt hole to make it all smooth and cleaner looking, bolted it tight to the lower bracket and then marked and drilled 3 new holes
Thanks again Nate and Rob for your help
Old 02-25-2012, 10:24 PM   #18
SCOTI
SCOTI's Avatar
Nicely done!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-25-2012, 11:13 PM   #19
jtp67-72
jtp67-72's Avatar
That's what I love about this forum--Everybody workin' together to get the perfect solution ........jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 02-26-2012, 12:24 AM   #20
Pop's C-10
Pop's C-10's Avatar
looks like they where meant to go together
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 02-26-2012, 12:50 PM   #21
robnolimit
robnolimit's Avatar
lookin' good.
