327 has no bolt hole!
My truck is a 66 c20 with a 327 and 4 speed. I was going to throw a new harmonic dampener on and lo there are no threads with which to use my installer tool. Is there some special tool to reinstall the balancer other than the obvious BFH? I really dont want to beat the hell out of my engine for fear of creating unnecessary work for myself.
#16876
Re: 327 has no bolt hole!
Some cranks did not have threaded holes. Don't beat the thing. You can mess up the mains. I heated my balancer in the oven on low temp and tapped it on. There are a lot of opinions on this topic. I suppose the best way is to drop the crank and have it pressed on.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#3 | |
"Where were you in '62?"
![]() Join Date: Jul 2004
![]() Quote:
Don't hit it with the hammer! Harmonic Balancer Installation Tools: http://www.jegs.com/webapp/wcs/store...itemPerPage=90 http://www.summitracing.com/search/?...on+Tool&RC=100
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Heat up the balancer as Sillyoldman mentioned, This can be done either in an oven, or in a pot of boiling water. In the over, be very careful you don't get it too hot so as to comprimise the rubber. At the same time, if you can,cool the crank snout. An ice pack should work. Then when you do go to install the balancer, don't mess around, get it driven on before the temps equalize. I would use a soft mallet or at least a block of wood between the balancer and hammer.
^^what he said^^
Just did that on my 230 and it worked like a charm. I pulled the rad and sat on top of the valve cover to get a comfortable spot to hold a piece of wood on the HB and tap it on. |
#6 | |
The installers work wonders when you have a bolt on type but the early ones like yours just use friction. The heat/ cold trick works well.
1966 Chevy Paneltruck 1992 gmc 1 ton 2wd 1997 burban Never be afraid to try something remember amateurs built the ark, the Titanic was built by pro's |
Most people wont agree with this , but the according to everything I have read the early 265 283 balancers were installed with a lead hammer at the factory ,it leaves no marks and works fine .. I have had one I made in my tool box going on 20 years ,I use it for the ones with no bolt holes in the crank ... I have an installer for the rest...
![]() Join Date: Jan 2011
BFH and a thick block of wood, the heating/cooling trick helps too...
I might ad after loosing one off an engine ,I do drill and tap all of them unless it is for a restoration, it only takes a few minutes in the mill .....
#10 | |
1962 C-10
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
Thank you everyone for your help! Im gonna give the hot and cold trick a shot this weekend. I do wonder, though, how they were put on at the factory. If i had taken it to the chevy dealer in 1966 how would they have installed it?
