![]() Join Date: Aug 2008
Factory power steering 65-66 hose routing
Hello does anybody have pictures of the hose routing on 65-66 factory power steering. Need the pressure side and return line . I have two 66 327 v8 one has a bracket on the inner fender to hold the hoses the other does not . The bracket looks to be factory what do others have send pictures
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Factory power steering 65-66 hose routing
I don't have any pics, but on my '66 C20, they just passed between the inner fender and the frame.
![]() Join Date: May 2007
The truck with the brackets is correct. Sorry I don't have any pics either.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Mike
I'll try and get those pictures of the 327 with factory air pullies and it also has the factory power steering hoses in tact. Still a drift of snow on the truck out there. Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
Mike I got out and snapped these today from my 66 327 truck. Mark
2 more of the side and where it passes below the radiator support and inner fender and out under the fender.
Mark is there a strap on the inner fender holding the hoses does this have ac also ? Thanks mike
Pictures of the power steering straps
Yes it looks just about like what you have. If you look closely you can see the strap and bolt next to that leave on the inner fender. It looks like mine is about in line with the ps pump pulley bit in the same location as what you have pictured on the inner fender. No other clamps that I saw it just used those hose covers where it passes under the inner fender. My truck is a 66 with 327 with factory air and power steering, pb, and 4 core radiator.
