Building Dreams out of Dimes!
How much taller is the ride height of a 4x4 compared to a 2wd?
Hey guys I have an '81 chevy with drop spindles and hangers. I was thinking about replacing the drop and picking the truck back up a bit.
I would like my truck to sit more like a truck. I dont mean like a jacked up 4x4 but with a nice working truck stance. How much taller are stock ride height 4x4s compared to a stock 2wd? Thanks!
1981 Chevy short/wide. SB400 350th |
Re: How much taller is the ride height of a 4x4 compared to a 2wd?
just a lift up front really to level it out for clearance. can be done with heavier springs.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
Will this put it at the same ride height as a stock 4wd? I really dont have anything to compare to because my truck was lowered when I bought it.
Is there any other way to level it without using heavier springs? I'm afraid if I get heavier springs it will make my truck ride more like tank.
#4 | |
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
Getting Old; Going Broke
I'm not sure mine is the same height as a real 4x4, but we replaced the front springs with HD springs and it really raised the front up. I was going after a "level" look without lowering the back. I am pleased with it.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
Put stock spindles and hangers back on it, and like RandyP did you could put heavier springs in it while it's apart. Should set up good. I'll bet you could find someone to trade you stock stuff for yours and help you do it just to get your lowering stuff.
"Whoever said money can't buy happiness has obviously never seen a speed shop! |
i believe this guy used 1 ton coils and then put taller tires on it. loks like a 4x4.....but its not
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
