02-09-2012, 10:51 AM | #1 |
WTB Working AC Divertor Box
Looking for a good working AC divertor box for a 67-72 C-10. Its the Box under the dash that controles where the heat goes. Thanks for any leads.
02-09-2012, 01:17 PM | #2 |
Re: WTB Working AC Divertor Box
I have a 72 with ac that I'm fixing to pull apart I can look at it tonight and let you know. Do you want just the part with the door or all of what's under the dash?
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
02-09-2012, 01:31 PM | #3 |
"Trucks with Class"
You may want to buy a new one. 99% of used ones have the flapper broken loose from the shaft. They look OK & the shaft moves but the door will be "limp" and not stay in position...resulting in heat/air coming out AC ducts when you are in the heater/def position.
Reinforcement plates can be made & welded to the shaft, but it is difficult and be careful of distorted housings from too much previous heat. Sorry, didn't meat to write a book. |
