Old 02-09-2012, 03:59 PM   #1
winslowgoodwin
Anyone know what the wheel base on this truck would be?
61 crewcab with a standard short bed.
winslowgoodwin is offline   Reply With Quote
Old 02-09-2012, 04:04 PM   #2
awbrown
Re: Anyone know what the wheel base on this truck would be?
add 32 inches to a short WB and you should be close....
awbrown is offline   Reply With Quote
Old 02-09-2012, 04:22 PM   #3
padresag
interesting as to how you would come up with that measurement?
I would say that it would be closer to 133"wb
my ambulance that I had was 145" w/b and had a full width door as the second door . that C/Cab has a short door.
By rondavid at 2007-06-09
By rondavid at 2012-01-03
ron
padresag is offline   Reply With Quote
Old 02-09-2012, 04:29 PM   #4
1963c-10
1963c-10's Avatar
Great looking ambulance.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-09-2012, 04:44 PM   #5
awbrown
I know for a fact that the common conversions done by arm bruster or osm were 30-32 inches long ........
Old 02-09-2012, 05:40 PM   #6
padresag
The frame ext on the ambulance is 30". compare the size difference of the door and the addition of the door post. I would wager that the door on the crewcab is no more than about 24-26"and the back door on the ambulance is the same width as a full size door.
ron
Old 02-09-2012, 05:46 PM   #7
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Short wheelbase is 115". Add 30" to 32" door and that would come to 145" to 147".
133" wheelbase less 115" for an original short box and you get 18" for the additional door.
Old 02-09-2012, 06:58 PM   #8
winslowgoodwin
The 147 sounds right to me. I'm going to get one of these next week and I just wanted to make sure it would fit on my bumper pull trailer. Other wise I'd have to take my longer gooseneck trailer which it's heavy. Cost me more fuel. Thanks for the help.
Old 02-09-2012, 07:52 PM   #9
creep
Registered Loser
creep's Avatar
I don't think you can use the door size to compare the wheelbases of the ambulance and the crewcab. The ambulance has bigger rear doors but the back wheels are closer to them than there are on the crew cab.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 02-09-2012, 08:49 PM   #10
awbrown
I towed mine 450 miles on my tow bar , not too many things you can use a tow bar for any more.... Towed my green one 1000 on a towbar behind a uhaul...
