Easy Rear suspension with shockwaves? W/pics of stance i am after..
I am planning out my 54 build. Will probably use the factory frame at this point over the S10 option even though i already have an S15 donor here. I want to use ridetech shockwaves all the way around the truck. I think i have the front suspension nailed down but choosing the rear suspension is starting to cause me headaches. I am not wanting to lay the boards on the ground so i do not need to or want to put a huge c notch in the frame however a small one that leaves the top of the frame intact would be fine. I just dont know what rear suspension system to go with. I am wanting to fit a fairly wide tire/wheel combination under the truck so i would like to keep all the components within the width of or under the frame rails. I do not have a lot of fabrication experience on something like this so i am hoping you guys can give me some good options to check into. Just as an FYI i am looking for a stance like the truck pictured below, at least when the bags are aired out. Below that are a couple pics of my truck for reference.Thanks.
![]() ![]() ![]() My Truck ![]() ![]() Last edited by DENALI; 02-09-2012 at 06:20 PM. |
![]() Join Date: Oct 2007
Re: Easy Rear suspension with shockwaves? W/pics of stance i am after..
you should look into useing the trailing arm rear suspension from a 67-72 chevy/gmc. a few people have used it on this site. hopefully they will chime in. i don't think there is alot of fab work to install it. hopefully this helps.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
leevon used this setup. look at his build thread project popeye
This is a TCI 4 bar set up with air bags but you could use shockwaves instead..
