Old 02-09-2012, 09:27 PM   #1
itstheshu
Wiring harness
Has any one used a EZ Wiring brand harness in there truck?
itstheshu is offline   Reply With Quote
Old 02-09-2012, 09:37 PM   #2
dsl30263
dsl30263's Avatar
Re: Wiring harness
Yep. My first total rewire, went without a hitch. Take your time. Get an assortment of grommets (Summit has a good one) and heat shrink tubing (Horrible Freight) and take your time. Jump on in there and good luck. You'll be proud.
dsl30263 is offline   Reply With Quote
Old 02-09-2012, 10:10 PM   #3
itstheshu
Re: Wiring harness
Which one did you use?
Old 02-10-2012, 07:24 AM   #4
dsl30263
dsl30263's Avatar
Re: Wiring harness
I used the 21 circuit one. It was just under $200. at the swapmeet in Moultrie, Ga. in 2011.
I would probably not get that many circuits because I had a bunch of leftovers.(Backup lights, electric windows and locks, etc.) Stuff I won't use. You can eliminate them if you want.
Old 02-10-2012, 09:37 AM   #5
Russell Ashley
Russell Ashley's Avatar
Re: Wiring harness
I also used the 21 ckt from EZWire. I'm well pleased with it. Get lots of crimp-on terminals and shrink tubing before you start. Also, lay it out and re-arrange the bundles to fit a truck. It seems to be laced out for use in a car when it comes. You can remove some of the wires for accessories that you don't plan to use or you can coil them up and hide them somewhere in case you want them later.
Russell Ashley is offline   Reply With Quote
Old 02-10-2012, 12:39 PM   #6
focusedontheprize
focusedontheprize's Avatar
Re: Wiring harness
Nice, I am also in the market for a wiring harness. Great info. Think the 21 circuit is the way to go and then just wrap the cords you don't use just in case later you change your mind.
focusedontheprize is offline   Reply With Quote
Old 02-10-2012, 03:01 PM   #7
_Ogre
_Ogre's Avatar
Re: Wiring harness
i used the ez wire 21 circuit on truk.
use the notes pages on back to describe what you did different from the instructions.
draw up any relay diagrams you use, more notes make for easy trouble shooting later on.
also download the instructions from painless to supplement your ezwire instructions.
shop air compressor timer
Old 02-10-2012, 04:09 PM   #8
oldcouple
oldcouple's Avatar
Re: Wiring harness
Yep, so simple even this guy can do it.
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 02-10-2012, 05:46 PM   #9
Russell Ashley
Re: Wiring harness
I forgot to mention before that the EZWire harness comes configured to plug in to a later GM column or an after market column with a GM style plug. If you are keeping your original column it's a little more work.
Old 02-10-2012, 05:58 PM   #10
Maximus
Maximus's Avatar
Re: Wiring harness
Yup, I used a GM column to make the ignition wiring and turn signal wiring easier.
I also got the 21 circuit EZ Wiring harness. everything was pretty simple to install, just take your time, and follow the tips they give. The only wire that was totally out of place that I can remember was the brake light switch and High beam wires, but I also changed my high beam with a later model universal so the plug is inside the cab on the side of the high beam button, instead of in the engine compartment at the end of the button.
Saved me from having to run the wires through the firewall and carpet covers the wires anyhow.
I bought my harness kit on eBay like 6 years ago, and it was only around $170 shipped
Maximus is offline   Reply With Quote
Old 02-10-2012, 07:11 PM   #11
Texas50
Re: Wiring harness
What other kits have you guys used that aren't the Ezwiring brand?
Texas50 is offline   Reply With Quote
Old 02-10-2012, 07:32 PM   #12
Rude Dude
Rude Dude's Avatar
Re: Wiring harness
I am using painless, but amercican autowire is really good setup friend used it on his 54. EZ wire are fab up off shore just check the crimps on back of fuse panel been have been known to have defective crimps. If you go with it I would add some solder on crimps.
Rude Dude is offline   Reply With Quote
Old 02-10-2012, 08:18 PM   #13
54 jimmy
54 jimmy's Avatar
Re: Wiring harness
used an ez wire in my 54 gmc. highly recomended. will use them again on my next project.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 02-10-2012, 08:36 PM   #14
OrrieG
OrrieG's Avatar
Re: Wiring harness
I have an EZ wire 21 set up that I have not installed yet. I had questions about connections to my column, and stuff not outlined in the manual. I got the company owner on first try and he was very helpful, said to call back if I ran into problems during install. I got it directly for $199.51 including shipping. It comes with connectors for different columns, alternators, and distributors. I got the 21 circuit one because I will eventually have 7 lead trailer plug, auxillary front and back lights, cruise and a winch.
Here is a good place for detailed information on the process. Scroll down to a drop down menu. General infor, specific infor and blow by blow account of his wiring experience. Lots of other good info and links too.
http://alanhorvath.com/54chevy/
OrrieG is offline   Reply With Quote
Old 02-10-2012, 08:52 PM   #15
candyx
candyx's Avatar
Re: Wiring harness
I used Painless Wiring 21 circuit kit and it went it pretty easy,didn't really have any issues at all with it.First time for wiring a truck or anything and there were no sparks or fire when i turned the key......happy to say.
candyx is offline   Reply With Quote
Old 02-10-2012, 09:11 PM   #16
rollinrooster
rollinrooster's Avatar
Re: Wiring harness
American Autowire for me. Cost a little more in the beginning but comes with everything you need.(all the stuff you end up having to buy later with the other kits)
rollinrooster is offline   Reply With Quote
Old 02-12-2012, 02:21 PM   #17
solidaxel
solidaxel's Avatar
Re: Wiring harness
I have used a EZ wire 21 and also a Its-a -snap 21 and they both work great, but I am leaning on a Its a snap for the next project, as it seemed a bit easier, or there was too much time passed to remember all the questions i had!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-12-2012, 02:27 PM   #18
c6_rob
c6_rob's Avatar
Re: Wiring harness
Im getting ready to do mine as well. EZ wire seems to have the best bank for buck.
c6_rob is offline   Reply With Quote
Old 02-12-2012, 02:34 PM   #19
UK 51
UK 51's Avatar
Re: Wiring harness
just finished rewire with an EZ 12 circuit, was pretty straight forward
www.broadstreetstudio.co.uk
UK 51 is offline   Reply With Quote
Old 02-12-2012, 03:22 PM   #20
Daze57
Daze57's Avatar
Re: Wiring harness
went with AAW -- good instuctions - all diagrams in color pretty easy to follow
Daze57 is offline   Reply With Quote
Old 02-12-2012, 04:47 PM   #21
Red Foreman
Red Foreman's Avatar
Re: Wiring harness
How many circuit # American auto wire did you guys go with? or better still which model or part No was it??
Red Foreman is offline   Reply With Quote
Old 02-12-2012, 10:52 PM   #22
jasonpickett
Re: Wiring harness
You can get the ez wiring kit on ebay with all the switches you need for $230. Also another good wiring company to go with is rebel wiring.
http://rebelwire.com/
jasonpickett is offline   Reply With Quote
Old 02-13-2012, 01:16 AM   #23
Daze57
Daze57's Avatar
Re: Wiring harness
Red Foreman
i went with #500481 of the AAW kit - 21 circuit - honestly it wasnt cheap
but i got a pretty good deal on it - i chose the 21 because i figure i will add more ''toys'' down the line and i wont have to source out what i need.
this is for my project 57 . good luck sir -and what ever you get read it all 6 times and install it once !
Old 02-13-2012, 01:24 AM   #24
Red Foreman
Re: Wiring harness
Thanks Daze57, I'm on the brink of buying a harness any day now & I had my eye on AAW, do you think its plenty long enough to the rear of my long bed GMC?
Old 02-13-2012, 01:39 AM   #25
Daze57
Daze57's Avatar
Re: Wiring harness
yes sir you should have plenty to work with . good luck on whatever you choose !
cheers mate !
