02-09-2012, 09:34 PM | #1 |
66 Front Grill help needed
Im working on a 66 CK10 and I need a drawing on how and what I need to put the grill in. All I have is a new grill and head light rings. I have headlight bucks on the way. I am starting at the front bulk head. Not sure of all what is needed. Does any one have one they can send me, or know of a web link that will show me.
Posted via Mobile Device |
02-10-2012, 12:48 AM | #2 |
60-66 Nut
Re: 66 Front Grill help needed
Does your grill have the mounting brackets on it? When you say 'front bulkhead' are you referring to the grill panel? You will need the wiring harness for sure.
Maybe if you can post a pic or two of what you do have, that would help line you out on what else you need.
02-10-2012, 12:56 AM | #3 |
I have a headlight wiring harness from a parts truck if needed. Not any cuts or nicks in the wiring.
02-10-2012, 01:02 AM | #4 |
if your grill doesnt have the mounting brackets in the back that the headlight buckets sit on ,I have a couple sets, ill send you a set if you just pay the shipping, send me a pm if you need a set.
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
02-10-2012, 01:35 AM | #5 |
Senior Enthusiast
This page from the LMC catalog might help a bit:
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=107 |
02-10-2012, 06:44 PM | #6 |
Dtkarst P.M. Sent
Thanks everyone now time to see what I have. Not much by the drawing Posted via Mobile Device |
