Old 02-09-2012, 10:51 PM   #1
198plus
198plus's Avatar
Will a 285/70/15 fit.......
Just wondering if anyone has tried a 285/70/15 on the rear of a fleetside with a 2" drop and a 71 rear end.
198plus is offline   Reply With Quote
Old 02-10-2012, 01:45 AM   #2
blackedoutharley
Re: Will a 285/70/15 fit.......
If you find anybody making that size tire let me know who!
285/70R15 is the same basic dimensions of a LT31x10.50R15 but in a standard 4 ply passenger car configuration (introduced by BFG in the mid 90's for the street rod market) but has since been long discontinued.
I have 31's on my '65 Fleetside in stock height and there is plenty of room to go down 2".
I believe the rear end in my truck came from a '69 + model truck.
blackedoutharley is offline   Reply With Quote
Old 02-10-2012, 02:00 AM   #3
SCOTI
SCOTI's Avatar
Originally Posted by blackedoutharley View Post
If you find anybody making that size tire let me know who! 285/70R15 is the same basic dimensions of a LT31x10.50R15 but in a standard 4 ply passenger car configuration (introduced by BFG in the mid 90's for the street rod market) but has since been long discontinued.
http://www.cokertire.com/catalogsear...t/?q=285/70R15
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-10-2012, 03:19 AM   #4
blackedoutharley
LOL!
Other than from Corky...
He bought the molds from BFG.
Old 02-10-2012, 03:35 AM   #5
irishmil
Newbie question...can you fit a bigger tire on a fleetside as apposed to a stepside on the rear
irishmil is offline   Reply With Quote
Old 02-10-2012, 12:35 PM   #6
protrash64
Resistance is Futile
protrash64's Avatar
I have a 295/50 on my 'burb; bagged. 71-72 rearend. Without knowing wheel specs this is the only way I know how to do it.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-10-2012, 04:13 PM   #7
65Gregg
65Gregg's Avatar
BFG did make them at one point, I had them on my 65 Fleetside before I dropped it. I use 275/70-15 BFG Longtrails on 8" truck Rallyes now and they are a pain in the you know what to take on or off. My drop is 3" springs w/2" blocks. In order to remove them I have to disconnect my shocks and lower spring to T/A mount, that allows the rearend(5 lug 72) to drop low enough. The issue is the wheel and tire will not clear my wheelwell inner lip. I know I could roll the wheelwell lip but really don't want to. I think I will take the 255/70-15 TA's off of the front and put them on the rear and put 235's on the front. If you want your wheelwells filled with rear tire the 275 will do it. Attached are pics of the before and after with the old wheels,The 3rd pic is a bad cell phone pic of how the 275 fits, my avitar has the current look.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 02-10-2012, 05:25 PM   #8
forestb
forestb's Avatar
I asked the same question and I think the response was no. Depending on how much the truck is lowered you should be able to fit a larger tier in a step side only because it has a higher wheel well.
forestb is offline   Reply With Quote
Old 02-10-2012, 07:59 PM   #9
gimmy 64
with 275-60-15 on 8in rim i have to put rear end on jack stands then jack up the frame to get tires on. this is with 3 in. lowering and leaf springs
gimmy 64 is offline   Reply With Quote
