Old 02-09-2012, 11:22 PM   #1
rcbildr
rcbildr's Avatar
Another "will it fit" question
I have a set of chevy 15x10 ralley wheels that I want to put on my 83 4x4. My friend has a set of 33" tires at a really good price. Will a 33" tire fit without a lift?
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 02-09-2012, 11:24 PM   #2
thinair
thinair
thinair's Avatar
Re: Another "will it fit" question
Not on a 10" wheel
thinair is offline   Reply With Quote
Old 02-09-2012, 11:29 PM   #3
rcbildr
rcbildr's Avatar
Thanks! That's what I was thinking too but wanted to be sure.
My Projects:
1978 Camaro Z28
Old 02-10-2012, 11:02 AM   #4
Zebb
Zebb's Avatar
Before you give up on it... Are you sure those rallies are 10"? Most aren't. If your springs are not too fatigued then you can run 33" tires on 8" rims. They are close and if you pound your truck they will hit. If you drive your truck sanely then you could probably get away with it.
Zebb is offline   Reply With Quote
Old 02-10-2012, 03:10 PM   #5
dbmx66
they'll fit. but your gonna have some rubbing.
before my brothers was lifted 10 inches we need the wheels and stock sized tires off it. he didnt want it sitting outside in the grass with no tires on it, so the only extras we had were 35x12.5 on 15x10 inch rims, they fit as well, but they rubbed.
dbmx66 is offline   Reply With Quote
