Bad motor mounts
I have a bad "shivering" in the mid to front area of my 86 chevy 305. It happens when I start on an incline and shakes like crazy until I back off of my accelarator. I replaced the U joints to no effect so I am thinking that its probably the Motor mounts. I think if it was the ball joints, it would shake all the time. What do you guys think? Thanks much in advance. Joe
Re: Bad motor mounts
could be a bent driveshaft. or rear end. i personally wouldnt bet on a motor mount..
Posted via Mobile Device |
Robert Olson Transport
![]() Join Date: Oct 2002
or the center bearing on a two piece driveshaft
Bad ball joints may not shake all the time, I've had them check out bad before the shakes start. (usually when I try to catch them.)
Pop the hood, start the truck, put it in gear (e-brake on) give it a little gas. If engine flops like a fish, your mounts are gone. Ok, I look for excessive movement when the engine tries to torque over, also listen. mounts may "clunk" when the engine settles back onto the mount. My as well check the tranny mount while your looking, at least rule it out. How's the trans. shifting?
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
I didn't think of the trans mount. I recently took out the trans to replace the ring gear. The mount may be loose/wore out. the drive shaft looks straight( I will put a straight edge on it to make sure). The engine doesn,t move around much at all when I hit the accelerator with it in gear, so it may not be the mounts. I think since the trans. mount is easy to replace, I will go ahead and do that first. Thanks much, I will post results when I finish.
Re: Bad motor mounts/ Trans. Mount Resolved
The Problem Was the transmission mount. The Truck even feels like it has more power no and with NO SHUDDERING!!! Thanks a Million, Joe
