Matching numbers
Hi Guy's
Fairly new to the forum as well as ownership of a 73 C10 but curious to know how to clarify matching numbers, my engine number doesn't match that of the VIN, thought maybe someone could possibly help here, the eng no is VO125TJZ, also should I expect to find digits from the Vin on the trans and rear axle. Thanks guy's ![]() |
#2 | |
Re: Matching numbers
Anyone? |
Engine tag and vin tag are different. The engine should be a 72-73 block to be correct
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#5 | |
V (Flint) 01 (Jan) 25 (25th day) TJZ (73 C10) |
Great investigative work Mick, all those years of watching the Rockford Files has finally paid off
[QUOTE=Red Foreman;5180824]Great investigative work Mick, all those years of watching the Rockford Files has finally paid off
![]() Don't forget Benny Hill, Fred Scuttle and The Bill, ![]() |
#8 | |
Hi tuffss,
Most engines were also stamped with a partial VIN that should match the vehicle it was installed in at the factory. It's often right next to that "V0125TJZ" engine assembly code you already found/decoded. But sometimes the partial VIN was stamped down on the side of the block near the oil filter. The ones stamped in that location can be rather hard to read since it was stamped on a rough cast surface. Quote:
Although it's for 67-69 Camaros, this page shows the locations of the assembly/date codes as well as the partial VINs on both the engine & trans --> http://www.camaros.org/drivetrain.shtml |
#9 | |
Cheers. |
Correct, Ray - no VIN on the rear axle.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
