Vintage 4x4s
Source for restoration correct oil cap and grommets
Anyone know where to get all the rubber pieces for a stock valve cover setup? Oil cap is a simple rubber cap that says "OIL" on it. There are 3 grommets as well. Maybe these will work?: http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={d074baad-8300-444e-95f8-1ea2470a8b09}&gid={e9c30a9c-f578-44ce-9dd7-2a064a97a45a}&GroupName=327%2f350+Valve+Covers%2c+Gaskets+%26+Grommets&pname=68-70+LH+%26+RH%2c+71-80+RH+Steel+Valve+Cover+Grommet&Referer=&Alias=&ptct=SGR-SR&CTitle=&
http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={e09594de-9983-4db3-b4ca-a64bbf6de10b}&gid={a46ae249-3f91-404e-9fef-69aad0f74905}&GroupName=Oil+Fill+Tubes+%26+Caps&pname=68-82+Valve+Cover+Oil+Cap+-+Push+In&Referer=&Alias=&ptct=SGR-SR&CTitle=&
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
Moderator
![]() Join Date: May 2007
Re: Source for restoration correct oil cap and grommets
I've bought the "oil" cap at a chain parts store (autozone, oreillys)
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Nov 2007
If it is in otherwise good shape, spray and soak that oil cap with easy off oven cleaner and it will strip the paint off and not harm the plastic/rubber. I got my grommets in the "help!" section at autozone.
In these days of imported crap, the can of easy off might cost more than an oil cap.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
