Help me i am stupid and i hate working on drum brakes
i put my new shoes on today and went to go put the drum back on and it would not go because the shoes where sticking out to far do i need to bleed the line off of that brake to let the shoes slip in to where they need to? Help my please guys the title of this post says it all
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
Seasonal Poster
Turn the adjuster dial thing...that should either pull them in or push them out according to the direction you spin it. It looks like a little gear
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
![]() Join Date: Nov 2002
release the parking brake 1rst.
i did
yea turn the adjuster all the way to shortest postion
'68 Fleet LWB orig 307 .030 over GM Hei/w Accel Super coil orig. stock TH 400. _______________________ “What we do for ourselves dies with us. What we do for others and the world remains and is immortal.” Albert Pine English author d.1851 |
1969 Custom 30 wrecker
Be sure to push the shoes together at the top which will push the wheel cylinder gizmos back in. When you remove the shoes, these usually pop out a bit.
Other than that, are you sure you have the shoe on correctly? The large one goes to the rear.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Almost Satisfied
![]() Join Date: Mar 2002
Here is what they should look like
mine don't have the e-brake parts though...
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
I wish my ride looked that clean '71step. That is a thing of beauty.
Silence is golden, duct tape is silver. - Scott |
Robert Olson Transport
![]() Join Date: Oct 2002
what ya need to do is to take the adjuster out. Unscrew the adjuster and clean it out good with some brake parts cleaner and before ya put it together put a dab of white grease ont he threads and in the cup on the other side screw it all the way so its closed reinstall it then use a brake adjuster tool and move the adjuster out ( from the backing plate you stick the tool int he hole back there) when the shoes are tight enough there will be just enough resistance when ya pull off the drum not too loose not too tight
#10 | |
Listening since '86
2007 Saturn Aura - hey it WAS a GM product |
Now the others dig........
![]() Join Date: May 2002
You don't need to remove the adjuster, just lift the lock above the adjusting gear and turn the gear away from you.
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
#12 | |
Re: Help me i am stupid and i hate working on drum brakes
