Old 02-10-2012, 08:26 PM   #1
TeXaS 86 C10
TeXaS 86 C10's Avatar
bench seats to captains chairs
can someone give me the run down on what will be needed and what to look out for or will it be a direct swap ?
i have a single cab... so do i need to make sure they came out of a single cab truck ??
i have bench seats and ive found some captains chairs with console that are the exact color as my interior. the seller has them advertised as 73-87 c10 and mine is an 86
thanks for the advice !!!
1986 LWB C-10 305/th400 Daily Driver and beer runner
TeXaS 86 C10 is offline   Reply With Quote
Old 02-12-2012, 01:31 PM   #2
88Jimmy4x4
88Jimmy4x4's Avatar
Re: bench seats to captains chairs
I think the ones your looking at on houston craigslist have armrest and are from a suburban. They stopped offering buckets for trucks around 1982
heres some good information
http://www.73-87.com/7387garage/inte...ry_buckets.htm
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 02-12-2012, 02:13 PM   #3
rs72z
rs72z's Avatar
The outer holes are the same the inners will need brackets fabbed or get the brackets from the burb floor.
rs72z is offline   Reply With Quote
Old 02-12-2012, 05:19 PM   #4
Pop's C-10
Pop's C-10's Avatar
and it doen't matter which style cab they came out of..like rs said..you have to fab up tha inner mounts & you good.
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 02-12-2012, 06:26 PM   #5
88Jimmy4x4
88Jimmy4x4's Avatar
http://houston.craigslist.org/pts/2844787335.html
yes you will need the brackets that are welded to the floor.
Heres mine that I bought off a member here, without these your gonna have to fab something.
after excess metal removal
1991 GMC Jimmy 4x4
Old 02-12-2012, 09:55 PM   #6
Mr. 250r
Mr. 250r's Avatar
Here's the ones i made at school i just got the measurements from my old suburban and remade them with thicker metal obviously they don't have the exact 110% replica of the originals but they work exactly the same, but as for the pictures it shows they didn't fit right because i had to bend the right tab up a little and grind a hair off the top right and then put the bend on them and they fit perfect, in all pretty easy to do if you can get the metal lowe's sells metal that would be perfect then you either need a small torch, clamps, welder, grinder and cutting wheel and some time and you'll be set
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
