3 speed to sm465???
The clutch is going out in my truck. It has a column shift 3 speed. Anyways, a buddy has a 465 trans in a 71 parts truck and he said I can have it for free. This might be a good swap for me as I pull a boat and travel trailer from time to time. What all is involved with this swap? Will I need a new drive shaft? The donor truck is a 3/4 ton leaf spring truck, mine is 1/2 ton coil spring rear if it matters. Thanks for any help.
Recovering Truck Driver
Just pull the bell housing, driveshaft, transmission and floor hump from the donor truck. You're gonna need it all.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
The clutch for the 4 speed should be a larger diameter and HD too I think.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
Robert Olson Transport
![]() Join Date: Oct 2002
better take the driveshaft too just in case
Resident Curmudgeon
![]() Join Date: Dec 1999
The driveshaft is going to be the biggest issue for you and you'll need the donor's driveshaft and carrier bearing. Here's why:
The 4 speed does not use a slip yolk as the 3 speed and auto's do, it uses a u-joint connection similar to the rear diff. The "slip" is in the driveshaft where the front and rear pieces join. The 3/4 ton uses a different rear differential, therefore the length of the rear shaft won't be correct to meet up with the 1/2 ton rear diff, plus the u-joint size is different. The u-joint ssue can be resolved using "hybrid" u-joints available thru NAPA, etc. So, you'll have to use the 3/4 ton's driveshaft and carrier bearing, hybrid u-joints at the rear diff, and either lengthen or shorten the rear part of the driveshaft (not sure which). Another alternative is to find a driveshaft off a 4 speed 1/2 ton truck, but these are not easy to locate.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
