02-10-2012, 09:17 PM | #1 |
Best way to remove angle bed strips
My bed strips are rusted and I think they are spot welded on. What is the best way to remove them? Any help will be great!
02-10-2012, 11:14 PM | #2 |
Re: Best way to remove angle bed strips
Well if you're not going to use them again I would put a grinder or torch on them. If you're just wanting to take them off and clean them up maybe you could just wire wheel them in place. What's your plan?
02-10-2012, 11:34 PM | #3 |
The 'Best Way" is to get someone else to do it for a case of beer!
But short of that follow above
http://s1299.photobucket.com/user/jb...23904108567829 |
02-11-2012, 10:12 AM | #4 |
I'm not going to use them. They are gone. I hope that the metal behind them are still ok.
02-11-2012, 11:09 AM | #5 |
As the other person is removing them you can drink the case of beer. Sounds like a good plan.
02-11-2012, 11:19 AM | #6 |
Cool
02-11-2012, 09:40 PM | #7 |
I did mine with a sawzall there are spot welds every 4 or 5 in I think some guys reccommend a spot weld bit
02-11-2012, 11:19 PM | #8 |
i drilled mine out and going back with new
02-12-2012, 10:15 AM | #9 |
It looks like I have rust behind the strip. I have not started to work on it yet because the front has just as much work. I hope all I have to do is spot fill the bad places and not replace the whole bed panel.
