Old 02-10-2012, 09:54 PM   #1
rudy350
Need advise for my new 1965 gmc truck
Hey guy im new here but after reading sum of the threads im hooked..
well i just got me a 1965 gmc truck long bed with a 350 sbc. for $100
and i want 2 questions answer please and advise on it ..
i want to go 5 lug with the front and rear what do i need to do to do this ?? ive heard i could use a 1971-1972 c10 rear end.
the other ive seen alot of guys in here that are proud of theyre 6 lug drum in the rear and 6 lug disk in the front. what do i need for this set up??
the help will be very helpfull thanks
rudy350 is offline   Reply With Quote
Old 02-10-2012, 11:11 PM   #2
Turkey
Turkey's Avatar
Re: Need advise for my new 1965 gmc truck
welcome from Florida. um....did you say $100? Killer deal if that's right. And killer truck as well. As far as I know 6 lug discs are a new kit you can get from lots of places like LMC, CPP, Ecklers and so on.
Turkey is offline   Reply With Quote
Old 02-11-2012, 12:24 AM   #3
rudy350
yeah $100 i couldnt belive it myself the guy used it just as a farm truck.. i was driving around he had sum horses on his farm i stoped to look at them he pull up we talk at the end of the day i sayd "nice truck" and he answerd" what this old hound? you want it?" i sayd sure but i dont got hardly anymoney he sayd "well how much u got on your pocket? ummm $100 ok shes urs with a original title one owner.
Old 02-11-2012, 12:35 AM   #4
rudy350
iam on a tight budget i really want the 5 lug, but what can i use of the junk yard to up date to a modern 6 lug front suspension so wen ever i need front rodors with bearings i can just got to the local autopart parts store and get them????
Old 02-11-2012, 02:58 AM   #5
Captainfab
60-66 Nut
Here you go......
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
The 60-66 FAQ Index at the top of the page has links to a lot of heplful threads.
Old 02-11-2012, 03:17 AM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Just think if you only had $50 in your pocket... She'd be yours for $50
Score!
Welcome to the forums.
66 C20 Service Truck:
Old 02-11-2012, 04:47 AM   #7
blackedoutharley
Don't GMC's have leave spring rear ends? If so wouldn't a 5 lug rear out of any GM truck up to about 1987 work?
blackedoutharley is offline   Reply With Quote
Old 02-11-2012, 07:45 AM   #8
biohazardbill
The 60's trucks rear ends were a little shorter than the 67 and up.
For the rear get a set of axle shafts from moser with the 5 lug setup and the drums from a later model. Moser makes axle shafts for our trucks with the 5 lug.
Vieod killed the radio star
The link above is for 5 on 5, but if you needed a different lug pattern, I am sure they could help.
Keep in mind, budget and modifying from stock dont always go hand in hand.
biohazardbill is offline   Reply With Quote
Old 02-11-2012, 10:20 AM   #9
dugvera@gmail.com
dugvera@gmail.com's Avatar
Welcome. And yes being cool is expensive!
Doug
66 4x4 GMC Suburban
76 4x4 Chevy Shortbed
dugvera@gmail.com is offline   Reply With Quote
Old 02-11-2012, 11:39 AM   #10
LostMy65
LostMy65's Avatar
My 62 gmc had trailing arms.
Old 02-12-2012, 10:55 AM   #11
rudy350
thanks captainfab, really help full..
Old 02-12-2012, 10:58 AM   #12
rudy350
thanks everyone for the helpfull advise,.. and yes my truck got leaf spring in the back.. mine has a three speed what kind of transmission cani use use to cruise around and take on the interstate???
Old 02-12-2012, 11:17 AM   #13
taclem
taclem's Avatar
If I remember correct, coils were stock on Chevy with leaf springs optional.
GMC were stock with leafs and coils were optional
taclem
taclem is offline   Reply With Quote
Old 02-12-2012, 12:11 PM   #14
kieth
kieth's Avatar
You can upgrade the front end to disc brakes by using the front crossmember from a 1072 - 1987 chevy pickup or a 1972-1991 suburban.....which is what I used on my 66 gmc pickup....91 burb....
the rear axle flanges can be redrilled for 5 lug for not a lot of money which is what I did on mine. be careful, I bought some 5 lug crgars for my truck before I realized that the truck 5 lug wheels are 5 x 5 pattern and the car 5 lug chevy that I had were 5 x 4-3/4, I ended up redrilling the front and rear hubs to accomodate the wheels (I got a really good deal on them and it was cheaper to redrill the hubs than to change the wheels. Go here is you want to see the build and the drilling of the rear axle flanges...... www.kieth.smugmug.com Kieth oh yes go to the 66 gmc gallery.....
kieth is offline   Reply With Quote
Old 02-12-2012, 02:38 PM   #15
joedoh
joedoh's Avatar
good googly moogly 100 bucks! you didnt get hurt there. good luck with the truck
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 02-12-2012, 04:32 PM   #16
rudy350
thanks (keith) does that apply if i want to stick to my 6 lug could i still use those years? with 6 lug????
(joedoh) yep i got lucky with it..
- what kind of headers can i use ?? i would like to have long tube headers that would bolt up to my 69 350 in the truck that will go on perfectly with out cutting anything in the truck?
Old 02-13-2012, 12:48 AM   #17
Captainfab
60-66 Nut
Hedman #69260's are the headers that are intended for the '63-'66 trucks. You can also use Hedman #69090's, but if you have a manual trans, the clutch bellcrank is a close fit.
As for the 6 lug disc brakes, that is all explained in the link I posted above. You can use the '71-'87 spindles with 6 lug aftermarket rotors.
Old 02-13-2012, 10:59 AM   #18
creep
Registered Loser
creep's Avatar
From what I've read 60-62 GMCs had trailing arms and 63-66 had leaf springs.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 02-14-2012, 10:58 PM   #19
rudy350
thanks captainfab ur a big help in my new and first '65 project..
