Tank removal?
Took out all 7 bolts and plates and unhooked the fuel line and sending unit wire, whats left for me to do? how do I undo the filler neck?
http://67-72chevytrucks.com/vboard/s...d.php?t=438550 ![]() ![]() 1994 Buick Roadmaster 1994 GMC Sonoma |
Re: Tank removal?
The filler neck is fitted to the tank [non removable] Pull tank towards pass side till filler neck is inside cab and slide out the drivers door or passenger door; Don't forget to remove the gas cap and if you can remove the filler neck grommet makes it easier;
Fuzzy |
Re: Tank removal?
so take off the cap and start playin tug of war huh
nec absolutum
Re: Tank removal?
pretty much. I've found that wd-40 help out. Spray some around where the filler neck slides through the grommet. Just remember, getting it out is the easy part. putting it back in right....
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants."~ Thomas Jefferson 1967 GMC C1500 LWB 250/3 on the tree- 1969 Chevy C/10 SWB 350/TH350 1996 Chevy Silverado LWB 350/4L60E 1997 Chevy K2500 350/4L80E ![]() ![]() |
