![]() Join Date: Sep 2004
Floor shift non tilt steering colmun
4 speed on the floor non tilt steering column out of a 68. Rough shape. Come with cracked wore sad steering wheel. Turn signal mechanism is broke. Lots of of slop in column, needs rebuilt. This is basically for parts only imo!
$30 plus the ride. ![]() ![]() ![]() ![]() ![]() ![]()
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) |
Re: Floor shift non tilt steering colmun
Bump
![]() Join Date: Mar 2011
would you sell me the directional housing and the other housing below and the directional mech if its any good as i am converting to floor shift.... price on those parts and ship to 07981
thanks jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
ANY INTEREST IN MY OFFER
What exactly are you after?
the 2 housings below the wheel the one that the cancel cam is in with the directional lever sticks out of ill take the canceling cam if it is not broke and the housing below that ... if it had a column shifter it would be hooked to it so those 2 housings is all i need no wheel no shaft no wire 2 housings below the wheel is all
thanks Jess
#7 | |
ok so the 2 red collars below the wheel is all i want if there are no dents in them I see in your post the turn signal cam is broke thanks again
is it still available? do you want to take it apart and sell me the parts i need ?
Id do $30 shipped on what your wanting as long as I can get it apart.
sounds good let me know when you have it apart and ill send the $s no rush
thanks Jess
