Old 02-11-2012, 10:24 AM   #1
65stepside
65stepside's Avatar
Axle Swap 78->65
Fellas,
I have a 65 chevy 1/2 ton with original everything pretty much. I have a donor 1978 1/2 ton that I'm pulling the enigne out for another project. I was thinking to take the front and rear axles, suspension, power brakes, power steering....everything and put them on the 65 frame. Is this possible without too much trouble. I know i've heard of the being done but I can't seem to find anything on here in regards to an axle swap such as this. Any help is appreciated thx!!!
Jason
1930 Olds 5 Window Coupe
1960 Chevy 1/2 Short Stepside on 1965 Frame 350/350
1960 Chevy 1/2 3'' Chop Short Stepside "FOR SALE!!!"
1966 Toronado
1971 Cutlass
1972 442
1978 Chevy 1/2 Long Fleetside
2001 Dodge 2500
65stepside is offline   Reply With Quote
Old 02-11-2012, 11:25 AM   #2
bama63
bama63's Avatar
Re: Axle Swap 78->65
its really easy here is the thread http://67-72chevytrucks.com/vboard/s...d.php?t=367260 and for the rear axle just remove the old trailing arm saddles from your old axle or buy new one and weld them on, also remember the 78 axle is 1.5 inches wider but does not present a problem
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 02-11-2012, 11:58 AM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
The front is super easy.
66 C20 Service Truck:
Old 02-11-2012, 03:38 PM   #4
chevyrestoguy
chevyrestoguy's Avatar
I just recently did the exact same thing to my '64. As far as the rear end, if you decide to lower it, I would highly suggest the Super Track Bar Kit from Early Classic. This solves the issue with the factory track bar (too short) and it also relocates the shocks for a much better ride.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 02-11-2012, 09:14 PM   #5
65stepside
65stepside's Avatar
Thanks Fellas!
1966 Toronado
1971 Cutlass
1972 442
2001 Dodge 2500
