02-11-2012, 05:00 PM | #1 |
It wont fit! engine swap?s Before i get the tourch and saws all!
I have finally gotten around to putting the small block into my 72 Long stepper. I have new motor mounts but the original tranny cross member is preventing me from installing the 305/350 combo. the original engine was a 250/3 speed. I would appreciate any all comments/suggestions on what needs to be modified to make the 305/350 fit. My main concerns are the old tranny mount and the floor board, but everything constructive will be appreciated.
This is were I try to sound clever and cool at the same time. |
02-11-2012, 05:10 PM | #2 |
Re: It wont fit! engine swap?s Before i get the tourch and saws all!
U need to remove the std trans cross member and install an auto cross member
Posted via Mobile Device |
02-11-2012, 06:03 PM | #3 |
thanks if there was a like button i would have hit it.
02-11-2012, 06:10 PM | #4 |
If your good like a buddy of mine was ( pasted away at 52 ) he could blow them all off in 5 mintues with a torch.
02-11-2012, 08:46 PM | #5 |
also if you didn't already know the motor mounts will need to move forward one hole from the 6cyl location. a V8 will fit in the 6cyl position but the dist will be very close to the firewall.
the manual trans bellhousing x member took me about 45 min to get out with a grinder (cut off wheels) and a dremel to slot the rivet heads, an air chisel to knock the rivet heads off , and also a sawsall to slice it in half so i wouldnt have to beat it out of the frame with a sledge. good luck
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
