Old 02-11-2012, 11:34 PM   #1
motiveauto
motiveauto's Avatar
64 4x4 leaf spring question
My father and I picked up his new truck, a 1964 k10. It needs some work but it runs strong but I noticed that one of the leaves is broken on both sides of the front end. So here my question; what springs fit in this truck? Will 73-87 work or are they a different length. Thanks again guys.
86 K20 6" lift
66 C10 LS2 T56
1947 Ford Rat Rod
Softail Deluxe
Softail Chopper
motiveauto is offline   Reply With Quote
Old 02-12-2012, 12:40 AM   #2
padresag
Re: 64 4x4 leaf spring question
64--66 frt. springs are a breed of their own I believe. you can always get some leafs made at a spring shop. but there must be a reason why they are breaking
ron
padresag is offline   Reply With Quote
Old 02-12-2012, 01:56 AM   #3
Captainfab
60-66 Nut
The '73-'87 K series springs are completely different. You could change the truck over to that style, but you would need to change the spring hangers and possibly another thing or two. You would also have to use either a 2.5" or 4" lift spring. I agree that having new leafs made would be the simplest fix
Old 02-12-2012, 09:31 AM   #4
duallyjams
duallyjams's Avatar
1 plus to changing to a later model spring it is longer so the truck would ride better.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-12-2012, 10:00 AM   #5
62 short step
62 short step's Avatar
When i had my 61 i changed over to 73-87 springs. It rode much nicer. The easiest fix liked metioned above it to get a spring shop to make a new one.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 02-13-2012, 09:53 AM   #6
motiveauto
motiveauto's Avatar
Thanks guys. I think we are gonna get some new springs made.
86 K20 6" lift
66 C10 LS2 T56
1947 Ford Rat Rod
Softail Deluxe
Softail Chopper
