fuel vent lines inside cab?
i noticed in LakeAnna's build thread that he was asking what these lines were for. VA72C10 said they are fuel vent lines that came only on the 72.
hopefully VA72C10 will see this and give me more information. i have a 69 c10 and i have these vent lines. my title says 1969. however, i don't have a vin on the dash in the windshield. the only place where i have a vin is on a name plate that's rivited on the drivers door jam. i suppose it's possible someone swapped name plates. what are some other ways to distinguish a year? other than a front clip. thanks.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
Re: fuel vent lines inside cab?
Does your gas pedal have a cable or the rod type?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
gas pedal is cable.
![]() Join Date: Apr 2008
Did you have disk brakes up front? Or on the title?
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
Unless someone changed the pedal, your cab is a 71 or 72. Does it have a raised part for the rear view mirror? If it does its a 71 if not a 72. VIN tag has probably been changed.
Roadtrip!
![]() Join Date: Feb 2003
The cable was 71-72. In 72 the rear view mirror would be on the windshield. In 71 there would be a raised pad for the rear view between the visors. Some 71s and 72s had a vent in the drivers door jamb. Is the tag still in the glove box door and does it match the door jamb?
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Would like to see the rivits holding the tag.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
the tag has been changed. from what ls1nova71 is saying, it's a 72.
the vin in the glove box doesn't match. the original color of the cab is green. the glove box has been primered a few times, but i can barely see under the hinge a little spec of green, so it's probably the original door. there is no raised area for the rear view mirror. hmmm, i have quite the fanagled truck here. a 72 cab, 68 front clip, ? yr fleetbed, ? yr frame, and a 69 title. i guess when people ask me what year my truck is, i can just say "it's a 67-72. i love 67-72 trucks so much, i can't help but to have a piece of all of them." any ways of identifing the frame?
I think the top of the frame near the steering box has a partial VIN number.
I hate when people bastardize vehicles.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
i will keep an eye out for that once i get to the frame work. i will need to figure out the year though once i order the tubular control arms.
