Old 02-12-2012, 11:01 AM   #1
williamsboys
williamsboys's Avatar
is there a diff in a 63 & 66 frame?
I have a 66 shortstep and i got it down to the frame ive redone all of the frame and suspinsion but the body on mine isnt the best. I found a 63 shortstep that has a way better body on it then mine so i was just wondering if the body on the 63 would fit and line up to my 66 frame. Any help or direction would be great. Thanks
williamsboys is offline   Reply With Quote
Old 02-12-2012, 11:19 AM   #2
losthope
losthope's Avatar
Re: is there a diff in a 63 & 66 frame?
in a similar thread on post #4 it shows diffrent frames 60-62 and then 63-66,looks like a 63 is the same as a 66 frame but i dont know for sure might want to wait till other members who know for sure chime in...i would think that they are the same and might have small slight differences !
http://67-72chevytrucks.com/vboard/s...ghlight=frames
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 02-12-2012, 11:22 AM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Losthope is correct.....63-66 frames are the same.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-12-2012, 11:24 AM   #4
williamsboys
Thanks guys.
Old 02-12-2012, 03:38 PM   #5
RickC63
RickC63's Avatar
I've been told that all 63 to 72's used the same frame. Someone please correct
Me if I'm wrong.
I'd like to be educated in telling all 60-66 Chevys apart by the fender emblems? Help?
Rick
RickC63 is offline   Reply With Quote
Old 02-12-2012, 04:10 PM   #6
padresag
63-66 are the same. there are changes in the 67-72
http://www.64moneypit.pages.qpg.com/...cks/index.html
ron
padresag is offline   Reply With Quote
Old 02-12-2012, 07:52 PM   #7
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
66 uses a different e brake system than 63-65, but the frame should still be the same.
Old 02-13-2012, 01:10 AM   #8
Captainfab
60-66 Nut
The '67-'72 frames are basically the same as the '63-'66 frames, but with a few differences. They can be modified to work with the '63-'66 bodies if needed.
There is a thread here somewhere that shows how to ID the years. It might be in the FAQ at the top of the page.
Me if I'm wrong.
Rick
