1# Drobmember in Germany
![]() Join Date: Aug 2008
another Frame question.....
......is there a different between a Frame with Coilsprings and a Frame with Leavesprings ?
thanks for helping me out of sleep less nights!
Pat Last edited by Apache63; 02-12-2012 at 01:23 PM. |
Resistance is Futile
Re: another Frame question.....
No. I have both and they are the same as far as I'm aware. I'm not sure if there are minor X-member differences or not. The center has no provisions for trailing arms. Leaves are hung just like any pick-up with hangers and shackles.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Only difference I noticed was on the leaf spring versions they have a stamping that resembles a slash on the left and right of the spring hangers.
Something like \Hanger/ if that makes sense. |
I'd agree with biohazardbill. My 64 suburban has the slashes stamped into the rail right next to the leaf spring hangers. In looking at the crossmember numerous times, it sure looks like the Chevy trailing arms would bolt right up, as the holes are all there.
Greg
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I believe the leaf spring frames have an extra crossmember at both the front and rear spring hangers. As far as I know it is not too difficult to convert a leaf spring frame to coils. All the holes should be in the frame already.
